Old Wed, Dec-05-2018, 02:47:38 AM   #11
JerseyDriver820
Reputation: 0 JerseyDriver820 is on a distinguished road
Default Re: subframe crack and reinforcement information
Reviving an old topic as the OP appears to having welding knowledge and chassis experience. I have searched and it appears that no one is gas welding cracks shut, or gas welding the reinforcement plate on.
The main way people attach these plates is by a MIG welder. Some people choose TIG, which can be somewhat expensive depending on how "proper" of you tool you think the job requires. I'm curious why gas welding and fusing the metal together with a filler has not been the preferred method. Gas welding has been a tried and true method of welding long before MIG or TIG became a thing.
Just curious and looking for advice as I'm gearing up to preform this work.
Jump to top JerseyDriver820 is offline   Reply With Quote
Old Wed, Dec-05-2018, 09:47:59 AM   #12
Eduki
Eduki's Avatar
Reputation: 0 Eduki is on a distinguished road
Spain
... Maybe because it's a vertical soldering?
Jump to top Eduki is offline   Reply With Quote
Old Wed, Dec-05-2018, 01:17:37 PM   #13
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
Overhead and vertical welding may be done with gas welding.
Old Wed, Dec-05-2018, 02:08:23 PM   #14
Eduki
Eduki's Avatar
Spain
May be, but it's not the proper welding.
Old Wed, Dec-05-2018, 07:58:51 PM   #15
JerseyDriver820
Is any weld the "proper" weld for overhead? With a mig gun its hard to see where your even pointing the thing sometimes. Also with a mig gun you can easily overheat an area.
Old Wed, Dec-05-2018, 10:28:55 PM   #16
staul m3
Reputation: 0 staul m3 is on a distinguished road
Yemen
Default subframe crack and reinforcement information
Gas welding would be a slow pain in the ass method with a huge heat affacted zone and would most likely damage more corrosion protection layers on the back side.
Tig is too slow, a good welder with plenty of thin sheet experience will mig it easily.
Jump to top staul m3 is offline   Reply With Quote
Old Thu, Dec-06-2018, 01:49:05 AM   #17
JerseyDriver820
Explanation I was looking for. Thanks Staul
Discussing subframe crack and reinforcement information in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
