Old Wed, Sep-23-2015, 05:40:30 PM   #1
PSUEng
Default Warped Valve Cover?
So I get a call from my local indy shop telling me that the cause of my oil leak between the head/VCG/VC is a warped VC. From visual inspection, I’m told it’s out approximately 1/8” and “high” in rear (near half moon), at the point of the leak. That warpage, combined with minimum fastening nuts for the VC has lead to the leak. My car currently has 66,500 miles.
Back around 61k, this same shop adjusted the valves and replaced the valve cover gasket and associated gasket bits. I ran the car about 3k miles and it was leaking, same spot, in the rear of the engine near the half moon profile. They replaced the gasket under warranty, and, 2500 or so miles later, here we are again with the same leak from the same area and they judge the VC as warped. Now, I trust this shop, they do great work and I’m not entirely doubting their diagnosis. However, the engine wasn’t leaking before they did the valve job, and I don’t believe they used OE BMW gaskets ( I think they use Victor Reinz or Elring). Now I’m not an expert on the gasket makers, but I’m questioning if this isn’t really an issue of “we should have used an OE BMW gasket but didn’t to save some money”.
That said, do I need to bite the bullet and R&R the VC? Or is it maybe worth it to throw an OE gasket in there and see what happens? I just have a hard time believing it’s a warped cover—how the F does that happen? I’ve had the car since 27k with no leak issues…now all of a sudden, at a mere 66k.
Old Wed, Sep-23-2015, 05:58:31 PM   #2
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
Default Re: Warped Valve Cover?
What do you mean by "minimum fastening nuts"?
Jump to top elbert is offline   Reply With Quote
Old Wed, Sep-23-2015, 05:59:24 PM   #3
Drewster
Drewster's Avatar
Have them show you in person - 1/8" is visible with the naked eye.
Did they RTV the half moons like you're supposed to?
Old Wed, Sep-23-2015, 06:06:20 PM   #4
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
if that VC warped you have bigger problems
Topo Chico
Old Wed, Sep-23-2015, 06:11:47 PM   #5
PSUEng
They are implying that there aren't sufficient attachment points for the VC to the head--there should be more. I dunno....I think I might take my chances on a fresh OEM gasket. I just can't understand how a VC warps, under regular driving.
I have to assume they properly sealed the half moons, but didn't ask and wasn't there to watch.
Old Wed, Sep-23-2015, 06:19:24 PM   #6
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
I am not going to question the integrity of the shop here.. but this sounds like a lot of CYA to just explain away a bad valve cover gasket or installation.
I have used both OEM and aftermarket. Both have not leaked, however I have seen a few Elring's leak right at the back bottom corner brand new out of the box and it was not the valve cover that was bad. Replaced with OEM and it was fine.
I would ask for proof the VC is warped, but that's just me. It is possible to get it wrong on install.
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Old Wed, Sep-23-2015, 06:57:34 PM   #7
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
on the valve cover gasket there are little pegs that need to fit into the holes of the engine, there is a one where the half moon is.
Jump to top deadlysyns is offline   Reply With Quote
Old Wed, Sep-23-2015, 10:56:18 PM   #8
fattycharged
can't even
Zimbabwe
Sounds far (very) fetched
Topo Chico
Old Tue, Dec-01-2015, 11:20:30 PM   #9
hemi8
M Power
Reputation: 0 hemi8 is on a distinguished road
Not far fetched at all, plastic valve covers do warp, especially as the miles add up. If I R&R'd the valve cover gasket myself or someone I trust that knows how to do it, 3 times with the factory gasket and it leaks after every install.....its warped.
Mike
2004 SMG M3, carbon black metallic w/cinnamon interior, OEM Euro Headers, Frank Smith engine & CSL SMG tuned, 300rwhp. Original SMG pump died @ 198k. Original clutch died @ 190k. Original rear diff. died @ 200k, driveshaft and axles shot @202k
Jump to top hemi8 is offline   Reply With Quote
Old Tue, Dec-01-2015, 11:31:02 PM   #10
Drewster
Drewster's Avatar
Mike
Plastic? You must have one interesting S54..
Discussing Warped Valve Cover? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
