Old Wed, Dec-05-2018, 01:39:53 AM   #81
herrubermensch
herrubermensch's Avatar
Reputation: 0 herrubermensch is on a distinguished road
Default Re: S54 Forged engine rebuild advice?
Originally Posted by . View Post
Are you still on the VAC valvetrain? Is it the same valve shim that gets spit every time or random/multiple? I know supertech recently came out with an updated design to fix the spitting shims above 8500 rpm issue. Wish they would have rolled that out before I got my set . I'm not sure if the VAC design maybe has the same issues.
Updated design of exactly what?
--Peter
Jump to top herrubermensch is offline   Reply With Quote
Old Wed, Dec-05-2018, 01:57:39 AM   #82
.'s Avatar
Reputation: 0 . is on a distinguished road
Originally Posted by mrgicm View Post
Everything in the head is from Schrick and the valves are VAC. The shim fells out after 100km. Firat I tought it was just one valve than we placed it back re measured everything and next it fell on 2-3 valves.
So did Supertech conclude the valves were the problem, how did they adress this problem?
--Peter
https://www.instagram.com/p/BmOpQNaF...d=wfhgrj31hs78
Its a new valve, retainer, and shim design apparently.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, Paul Claude tune, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5 twin-piped resonated section 2, SGT scza section 3.
Drivetrain: Clutch Masters FX725, Clutch Masters Hydraulic TB, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance shift knob/e-brake/pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Wed, Dec-05-2018, 10:52:41 PM   #83
stash1
Interesting, wonder if the new design has enhanced rpm capability and has anyone tested it...not much info in that instagram blurb.
'04 AW/IR...some mods
Old Thu, Dec-06-2018, 12:46:09 PM   #84
.'s Avatar
I asked in the comments and didn't get a response. Yeah sucks theres not much detail. A couple people on Michael Essa's page said they're running them as well and it fixed their spitting shims issue but didn't say to what rpm. I figured if I ever pull my head off again I'd give them a call and find out.
IG: Zach_e46M
Old Sat, Mar-02-2019, 06:52:19 PM   #85
herrubermensch
Anyone have any experience with the uprated Supertech valve kit with the longer valve stems and valve lash caps in lieu of shims?
--Peter
Old Sat, Mar-02-2019, 09:26:13 PM   #86
digger
i would have thought they have a test mule not rely on customers to test parts
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Discussing S54 Forged engine rebuild advice? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
