Old Thu, Feb-18-2016, 07:46:13 AM   #21
Mike RT4
Reputation: 0 Mike RT4 is on a distinguished road
United Kingdom
Default Re: S54 Forged engine rebuild advice?
Originally Posted by mrgicm View Post
Ok so here is the final confirmed order
JE Pistons 87.5mm bore with 12.5CR
Arrow forged rods with arp bolts
schrick 288/280 camschafts
Schrick DLC followers
Schrick valve spring
Schrick retainers
Maneliey oversize 1mm+ intake valves
Maneliey oversize 1mm+ exhaust valves
uprated main bearings
uprated con rod bearings
Full ARP head set
Uprated head gasket
Supersprint headers
CSL style airbox
The mapping will probbably be done by Aplha N performance Germany at their shop as they told me they would need the car for a good 5 days to run a good clean map...
Just cant wait to have this done as hoping for at least 400hp on 100oct gas...
I'd be very interested in how you get on with the mapping process .
CSL No 44 - AP 5575 6-pots front, PF 356 x 32 discs, RS 29 pads / AP 5144 4-pots rear, RS 29 pads - Castrol SRF / Supersprint full system from headers back, inc race cats with "Race" backbox / BAD 4-way coilovers / CMP rear beam and trailing arm bushes / Turner rear camber arms
Jump to top Mike RT4 is offline   Reply With Quote
Old Sun, May-08-2016, 07:06:29 PM   #22
mrgicm
mrgicm's Avatar
Reputation: 0 mrgicm is on a distinguished road
Croatia
So after a while the parts have Finally arrived, when the UPS called to ask me when I was home I just told them im comming right to you to pick it up:
Just a right fit
All the full Schrick valve gear
All unboxed to see if all is here:
Karbonius Airbox - NOW THATS WHAT I CALL A PIECE OF ART
iNSIDE view:
I just cant get over how beautiful and high quality finish Karboinius does on the Airbox.
Will definetley order the full carbon roof next.
I hope the engine will be in the car and fired up in the next 2-3 weeks..
For mapping I have arranged with Alpha-N Germany to send the car to them for mapping and than immeadetley to some testing on the Nurburgring.
Jump to top mrgicm is offline   Reply With Quote
Old Sun, May-08-2016, 07:32:56 PM   #23
stash1
^^^ Nice update OP! Hardware looks like the business, & should be capable of producing around 400WHP w/some quality tuning. Sub'd for more updates!
'04 AW/IR...some mods
Old Tue, Jul-19-2016, 10:55:36 PM   #24
mrgicm
mrgicm's Avatar
Croatia
Hello,
My engine is almost compleate and will be going into the car next week.
I would just need your thoughts on the headers, I still havent bought them and is it absolutly a must or can I add them later on, whould there be a significant loss of power on a fully build engine?
I plan on removing the cats fully and I have a Milltek full exaust?
Old Wed, Jul-20-2016, 02:25:58 AM   #25
stash1
I would go w/either the SS V1's, or the Epic/Bimmerworld headers in order to fully take advantage of your built engine...they will maximize your HP potential.
Old Mon, Jan-30-2017, 08:22:33 PM   #26
Flow
Flow's Avatar
France
OP, where is our update ? We need #s and videos
2004 M3 TiAg / LSB SMG
Old Mon, Jan-30-2017, 08:48:09 PM   #27
stash1
Haha, damn, completely forgot about this build...yeah, x2 on the update if it ever happened.
Old Wed, Feb-01-2017, 04:09:08 PM   #28
AndrewLang
Lang Racing Development
AndrewLang's Avatar
Reputation: 0 AndrewLang is on a distinguished road
Are you going to limit the Vanos so your valves don't clip each other?
Store | Facebook | Blog
Jump to top AndrewLang is offline   Reply With Quote
Old Wed, Feb-01-2017, 08:24:16 PM   #29
digger
Andrew,
how is this normally achieved mechanically without doing a full vanos removal? are there kits available?
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Wed, Feb-01-2017, 08:44:38 PM   #30
AndrewLang
AndrewLang's Avatar
Originally Posted by digger View Post
Andrew,
I'm working on that, most people don't need it. Also without a pretty thorough engine building process its hard to know how much you would need to limit the VANOS unless someone does all the work for you.
Discussing S54 Forged engine rebuild advice? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
