Old Sat, Nov-17-2018, 12:39:26 PM   #51
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
Default Re: Noise for few seconds at first startup
Zaharias, you're right. I'm referring to the screws that connect the two parts shown in your photo. Incidentally, I think I've solved my problem, but thanks to those who offered help.
Jump to top BubbaTree is offline   Reply With Quote
Old Sat, Nov-17-2018, 12:41:06 PM   #52
Eduki
Eduki's Avatar
Reputation: 0 Eduki is on a distinguished road
Spain
And how you did it, if this could be for help for any other in the same situation?
Jump to top Eduki is offline   Reply With Quote
Old Sat, Nov-17-2018, 06:13:06 PM   #53
BubbaTree
BubbaTree
I was hoping no-one would ask that question because the answer is a little embarrassing. I went to HF and bought the correct size ( E-5) torx wrench! I had been using my old E-6 and rounded off the head of one screw, but the E-5 worked fine! All is locked down now, and I'll again run the vanos test to see what happens.
Old Tue, Nov-27-2018, 12:40:07 PM   #54
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
So I found an interesting "fix" to my issue which has greatly reduced the startup noise....
I changed the oil from Castrol TWS 10W60 to Liqui Moly 10W60.....
This was simply a planned oil change at 5-6000 mile. After a day of driving I noticed the car barely makes the rattle sound upon startup after sitting for 6+ hours.
Not saying it'll fix all your issues but my startup rattle is so quiet now it's not noticeable which seems normal to me!
Jump to top ClutchKickChris is offline   Reply With Quote
Old Tue, Nov-27-2018, 01:19:00 PM   #55
zaharias
Greece
Thanks for the input.
Keep as updated while you do some miles.
I also use Liqui Moly but know I have Pentosin since my mech was out of stock on LM.
I will try a used Vanos valve body as Raj said a valve may have some leak and report back.
Jump to top zaharias is online now   Reply With Quote
Old Tue, Nov-27-2018, 01:43:46 PM   #56
LM has a slightly higher viscosity and a higher cold pour (not actually a good thing) than TWS, so that could be it. Maybe not ideal in cold climates, mind.
Keep in mind, the old oil has thinned out and the new stuff is at its best. Any perceived change may go away over time. Might be so slow you don't even notice.
_
Old Wed, Dec-05-2018, 02:21:16 PM   #57
zaharias
Greece
Could this be a faulty Vanos pressure accumulator?
Old Wed, Dec-05-2018, 05:20:11 PM   #58
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
Changed it, no improvement.
Jump to top Cmamainer is offline   Reply With Quote
Discussing Noise for few seconds at first startup in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
