Old Mon, Nov-05-2018, 01:02:50 PM   #41
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
Default Re: Noise for few seconds at first startup
I have this EXACT SAME noise and behavior pattern as well. It occurred about 8 months AFTER I did a complete vanos rebuild with all beisan parts. When I was in there I found the upper timing chain guide in 2 pieces as well and replaced it of course.
This has me worried that somehow the new one could now be broken.
Jump to top ClutchKickChris is offline   Reply With Quote
Old Mon, Nov-12-2018, 01:58:27 PM   #42
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
My engine has made this sound since I bought the car in 2006. I've installed every VANOS part made by Beisan, aside from the exhaust hub, which is the one that came with the car. New vanos internal and external oil pressure regulators, new CPV valve, recent valve adjustment, all of which have made zero difference in this sound. At this point, I'm convinced that this engine has no way of retaining oil in the cylinder head, particularly the camshafts, so it rattles on cold startup, until the pump gets oil back into the valve mechanism. I've done too much research trying to identify the real purpose of the CPV, and seem to get mixed input. I would think that given it's name, it should retain a constant oil pressure in the cylinder head while the engine is not running. Does the non-M engine have this characteristic? I would think not, since it has hydraulic valve lifters. At this point, I'm convinced that this engine has another design issue, in the same vein as the exhaust hub, and I'm going to live with it until a cause and fix are positively identified.
Jump to top BubbaTree is offline   Reply With Quote
Old Wed, Nov-14-2018, 06:18:20 PM   #43
zaharias
Greece
I think it's related to the oil pump..
Iam thinking of changing it in 2019.
Jump to top zaharias is offline   Reply With Quote
Old Wed, Nov-14-2018, 06:56:39 PM   #44
mpwr92
Reputation: 0 mpwr92 is on a distinguished road
I have this issue it is in the Vanos unit you can rebuil as much as you like it’s draining back bad put a oil pressure checker on the Vanos you probably find ur pressure drops as soon as you switch the car of to 0 if this is the case get either a new unit or a know good one also check your pressure at operating temp you probably find it’s not making 1450psi of pressure there for you have a lazy Vanos. This is where the start rattle occurs if u done eveything I’m almost certain ur problem is that.
Jump to top mpwr92 is offline   Reply With Quote
Old Fri, Nov-16-2018, 03:33:17 PM   #45
zaharias
Greece
Originally Posted by mpwr92 View Post
I have this issue it is in the Vanos unit you can rebuil as much as you like itís draining back bad put a oil pressure checker on the Vanos you probably find ur pressure drops as soon as you switch the car of to 0 if this is the case get either a new unit or a know good one also check your pressure at operating temp you probably find itís not making 1450psi of pressure there for you have a lazy Vanos. This is where the start rattle occurs if u done eveything Iím almost certain ur problem is that.
Sent my video to Raj (Beisan) and he told me "the cold startup rattle possibly being caused by a vanos solenoid valve body leaking valve."
Old Fri, Nov-16-2018, 07:36:26 PM   #46
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
Do you mean the VANOS oil pressure valve or one of the solenoid operated valves on the body itself?
Jump to top Cmamainer is offline   Reply With Quote
Old Fri, Nov-16-2018, 08:42:04 PM   #47
BubbaTree
BubbaTree
Not meaning to hijack this thread, but, since my car has these same symptoms, I'm removing the electrical solenoid from the valve body to clean the valve body. I've rounded off the head of one of the external torx screws that mounts the solenoid to the valve body, and urgently need a replacement. Looks like they are not available as a separate part from BMW.
Appreciate any help, and for the record, I also posted this in the FS/WTB section, but thought someone here might be of help sooner than later.
Old Fri, Nov-16-2018, 08:53:50 PM   #48
Vanos body torx bolts:
https://www.fcpeuro.com/products/bmw...er-07129905554
https://www.fcpeuro.com/products/bmw...er-07129905537
https://www.fcpeuro.com/products/bmw...32-11367838083
measure your lengths, don't know which one you need, but those should cover you.
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Fri, Nov-16-2018, 11:35:04 PM   #49
BubbaTree
BubbaTree
Thanks for the suggested vanos screws, but those seem to be replacements for bolting the valve body to the vanos gear drive. The ones I need are much smaller, maybe E5 torx, and attach the electrical solenoid to the valve body. I have a photo of what I need but can't seem to attach it here.
Old Sat, Nov-17-2018, 06:05:59 AM   #50
zaharias
Greece
I think he means this one.
Discussing Noise for few seconds at first startup in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
