Old Sat, Aug-18-2018, 01:02:42 PM   #31
whips333
whips333's Avatar
Default Re: Noise for few seconds at first startup
Originally Posted by zaharias View Post
Did you install Beisan's vanos rattle kit as well?
Old Sat, Aug-18-2018, 01:06:59 PM   #32
zaharias
Greece
Yes, even though my vanos didnít do any rattle.
Itís only on cold start and for one second.
Jump to top zaharias is offline   Reply With Quote
Old Sat, Aug-18-2018, 09:21:52 PM   #33
zaharias
Greece
Definitely sounds like a chain rattle
Could it be any of No1,2 or 4? Cause No3 is replaced and No5.
http://bmwfans.info/parts-catalog/E4...timing_chain_2
Old Sat, Aug-18-2018, 10:36:22 PM   #34
HassanEido
HassanEido's Avatar
Lebanon
Did u check the oil pressure or vanos? it needs a to be at 110 bar. Check that and report back .
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Fri, Aug-24-2018, 07:38:40 PM   #35
zaharias
Greece
You mean vanos test with GT1?
How can i check the oil pressure?
Is there any valve inside the oil filter housing that could be stuck?
Old Fri, Aug-24-2018, 08:48:41 PM   #36
HassanEido
HassanEido's Avatar
Lebanon
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Sat, Aug-25-2018, 12:30:31 AM   #37
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
I installed a new accumulator and there was no change
Jump to top Cmamainer is offline   Reply With Quote
Old Sat, Aug-25-2018, 07:17:02 AM   #38
zaharias
Greece
Another related topic
http://www.m3forum.net/m3forum/showthread.php?t=591696
Old Sun, Aug-26-2018, 12:37:04 AM   #39
Eduki
Eduki's Avatar
Reputation: 0 Eduki is on a distinguished road
Spain
Default Re: SOLVED: Noise for few seconds at first startup
My co-worker's M3 has exactly the same symptoms.
Could it be also the oil pump chain being loose and rubbing the pump neck?
Or the timing chain itself, slide rail at the right or twin chain tensioner at bottom left?
He has done also a complete Vanos overhaul.
Jump to top Eduki is offline   Reply With Quote
Old Sun, Nov-04-2018, 06:31:28 AM   #40
mpwr92
Reputation: 0 mpwr92 is on a distinguished road
Anyone sort this issue?
Jump to top mpwr92 is offline   Reply With Quote
Discussing Noise for few seconds at first startup in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
