Old Tue, Dec-04-2018, 12:30:16 AM   #21
bosundave
Reputation: 0 bosundave is on a distinguished road
Default Re: Square Setup Front Tire Size
Originally Posted by M3Lyfe617 View Post
I don’t have 18s, but point taken.
19's? OIY! Even worse. You will be miserable. Bad ride and destroy rims.
My car came with BMW OEM 19's. I went to a high end three piece 19's (255 F and 275 Rear)
Then I bought D-Force ultra light weight 18X9.5 ET 35 for the track....BF Goodrich R1's track and Michelin Pilot Super Sports for the street 265/35-18. I liked the ride, HANDLING, and set up so much I never ran the 19's again.
19's for looks but 18's FTW. The D-Force racing wheels have proven to be more than strong enough for South Florida streets...LOTS of RR tracks! I get the run-out checked when ever I am having tires mounted. Turner, Mod Bargains and others sell this wheel. The LTW-5
You might want to get a set of 18's some time. Apex make a great wheel too, the ARC-8. I had four sets of different wheels at one time (a while ago). Try 18's. I never thought I was going to run anything but 19's. I was wrong.
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Old Tue, Dec-04-2018, 02:51:55 AM   #22
M3Lyfe617
Reputation: 0 M3Lyfe617 is on a distinguished road
Thanks for the info. helpful
06 ZCP | Macht Schnell Spacers 20MM | GC Plates | KW V1| E60 Shifter | Eibach F&R Sways | ZCP SQ. | Morimoto LED Fogs
05 X5 4.8is | H&R spacers 30MM | X-pipe | Lowered
| FOR SALE
Jump to top M3Lyfe617 is offline   Reply With Quote
Old Tue, Dec-04-2018, 04:25:24 AM   #23
Andrebxp
Reputation: 0 Andrebxp is on a distinguished road
I run a 275/35/18 Michelin PSS with about 2.5deg of neg camber up front and 2deg in the back. Ground control coilovers and L + R swapped stock strut mounts.
No rubbing whatsoever. Car is pretty darty with 0 front toe but front grip is mega good.
Jump to top Andrebxp is offline   Reply With Quote
Old Tue, Dec-04-2018, 05:07:09 AM   #24
bosundave
Sweet. Do you run FULL caster?
You said "darty". This is why I recommend just a TAD of Toe In for front and rear tires. Too much toe and you get tire wear. Zero toe and you loose some straight line stability.
Toe OUT works great on the track only.
Old Tue, Dec-04-2018, 05:15:24 AM   #25
Andrebxp
My caster isn't adjustable since i'm running flip flopped stock mounts but its about 7.8deg of caster which is the upper end of the recommended spec iirc.
If this isn't a toy I'd also recommend a hair of toe in. Mine is just a toy so I don't mind dealing with it because of the lovely 0 toe turn-in.
Old Tue, Dec-04-2018, 05:50:12 AM   #26
Toe out is scary on the track, unless you run short tracks or autox.
0 front toe and very little rear toe provides the best of both worlds for street and track.
Old Wed, Dec-05-2018, 02:32:03 PM   #27
bosundave
You are correct.
I did run toe out at Homestead HPDE which is just an over sized Autocross IMO. I don't like that short, highly technical low speed course. But the toe--out really did help with the numerous tight turns and hair pins.
I LOVE Sebring which is a real 3.7 mile race track. No way would I run Toe-out there. Even my car can hit some high speeds on the straightaways. Must have stability. Having camber adjustment really helps with stability. I just give it FULL camber that the plate can give me. This is the normal recommendation, and it works.
Daytona is on my bucket list. That is even a faster course!
Old Wed, Dec-05-2018, 02:43:57 PM   #28
DirtyEtzio
DirtyEtzio's Avatar
Reputation: 0 DirtyEtzio is on a distinguished road
I run square 275/35 18's, Toyo RR's on Apex ARC8 18x9.5 et35.
With the new Essex AP racing 9668 calipers, I had to put a 12mm spacer on the front wheels. With the spacer, the tire is rubbing the fender under hard compression at the track with -3.1-ish camber.
Prior to this kit (had the Essex AP 4 piston prior), ran a 2mm spacer simply to give myself a little piece of mind (was unnecessary to clear the caliper, just looked TOO close) and had no issues with rubbing.
Plan is to go -3.5 on the front, -2.5 on the rear.
  • MCS 3-way Remotes, front/rear Hotchkis sways
  • Some sort of crazy DiffsOnline 3.91 diff
  • SuperSprint V1.
    BW Race Exhaust.
  • Essex AP Racing 9668 front brake kit
Jump to top DirtyEtzio is offline   Reply With Quote
Old Wed, Dec-05-2018, 03:58:30 PM   #29
Andrebxp
You could also try ruining an Apex EC-7 wheel; it has more brake caliper clearance for the same offset.
Old Wed, Dec-05-2018, 06:49:30 PM   #30
You are correct.
You mean full caster for stability...
Discussing Square Setup Front Tire Size in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
