Old Wed, Dec-05-2018, 07:49:04 AM   #9451
Lightship
Lightship's Avatar
Reputation: 0 Lightship is on a distinguished road
Default Re: What did you do to/for your ///M today?
Well, from the weekend -
Removed rear bearings, hubs.
Installed new bearings, hubs and axles.
New park brake shoes, springs etc.
New injectors.
Cleaned the ICV.
Installed new throttle position sensors.
Buttoned up the intake after the injector job and the complete cooling overhaul done the previous week.
I used the Posi-lock 108 puller to push both of the old axles out. Once out I hit the splines on the old axles with a grinder, re-installed them into the hubs and let them loosely sit against the diff flanges. Then used the Posi-lock again to pull the hubs off - pushing against the old axles.
Getting the new axles in I used the proper tool to pull the axles into the hubs, no banging or bashing on CV's.
It's been a fun couple of weeks!
The beer tastes o so sweet tonight!
2002 . RHD Euro E46 M3 . Avus Blue . 260 style E92 18" wheels . Bilstein B6 . CSL Springs . CSL Sways . CG . Drexler Diff . KoyoRad .
Win at the slowest possible speed!
Journal: http://m3forum.net/m3forum/showthread.php?t=492037
Jump to top Lightship is offline   Reply With Quote
Old Fri, Dec-07-2018, 01:40:59 AM   #9452
hatuey
hatuey's Avatar
Reputation: 0 hatuey is on a distinguished road
Nice.
Jump to top hatuey is offline   Reply With Quote
Old Sat, Dec-08-2018, 02:10:57 AM   #9453
Lightship
Lightship's Avatar
Bled the brakes and clutch after the CDV delete and the ECS braided line when in. Gear changes are sooooooo much better!
Coolant bleed.
Buttoned everything back up after the last month of working on the car.
Drove to the bottleshop as a test drive and had a few cold ones to sign off the job!
Car drives beautifully. Feels new.
Next: rod bearings, oil cooler, power steering lines/reservoir, fuel pump...
After that it's wish list stuff.
Old Sat, Dec-08-2018, 02:44:01 AM   #9454
The Kook Abides
Reputation: 0 The Kook Abides is on a distinguished road
New front windshield.
Pilkington OEM glass.
Wow...So much better.
Jump to top The Kook Abides is offline   Reply With Quote
Old Sat, Dec-08-2018, 03:53:30 AM   #9455
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
Default What did you do to/for your ///M today?
I took apart my rear deck to fix the rattle and dye the deck back to black. Upon taking out the c-pillars I broke one clip and it looks like a PO broke another and the part that attaches behind the light so I fixed it up at work tonight on my break with a little 6367 and 120 glass.
Jump to top delvin is offline   Reply With Quote
Old Mon, Dec-10-2018, 09:18:57 PM   #9456
R60BBA
Reputation: 0 R60BBA is on a distinguished road
United Kingdom
Quick Wash Video
Here's a short clip I did of washing the exterior of my car a couple months back.
I wash the exterior of my car more or less every week (weather permitting) and the interior once a month. As it is a weekend toy my interior doesn't really require much other than a quick hoover and every 3 months I protect the leather with Simoniz.
For those interested in how I wash my car: I use the snowfoam / 2 bucket method and wax the car every 3 months.
As you will see in the last image of the video, there are quite a few swirls in the paint. However I won't be addressing these with a detail as I am putting her in for a full respray next year.
N.B. this is not a tutorial on how to wash your car (there are already loads on YouTube), it's more about just having a bit of fun with the GoPro.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
https://youtu.be/y0ymv8jOC0Y
Jump to top R60BBA is online now   Reply With Quote
Old Tue, Dec-11-2018, 12:17:33 PM   #9457
rhythim
Career parts guy
rhythim's Avatar
Reputation: 0 rhythim is on a distinguished road
Completed the OEM LED tail lamp retrofit JUST in time for it to stall while idling in the driveway as I was wrapping up the LSZ recoding. It restarted immediately, then promptly started running like ASS and threw a P0172/P0175 Bank1/Bank2 rich, 90/91 fuel trim control codes. Stinks of raw fuel at idle and stalls randomly.
Ugh.
Broke out the scanner, all 4 O2 sensors switching normally (I'm catless, so the rear 2 are coded out/irrelevant), LT fuel trims at -20%, MAF reading ~18-20kg/hr at idle, 20%ish engine load at 29 degrees ambient temp with the engine not fully warmed up. Other than fuel trims, readings are basically within normal ranges from what I've read.
Guess I'll be pulling it in the shop this weekend and checking fuel pressures and looking for leaky injectors.
Sent from my SM-G928V using Tapatalk
'01 M3 vert, 47th production convertible built, 97th overall. Not just an early one, a REALLY early one.
'67 Mustang vert (original owner)
"What do you mean you 'have a little job for me'?"
-Hercules
Jump to top rhythim is offline   Reply With Quote
Old Thu, Dec-13-2018, 06:42:04 PM   #9458
BTB
BTB's Avatar
Reputation: 0 BTB is on a distinguished road
Installed Yakima whispbar and 40" wind deflector for move to CA! Got a soft luggage carrier that I'll be hauling on top
UIUC / TU Munich Mechanical Engineering 2018
2003 ///M3 6MT Coupe Imola Red/Black Napa, slicktop, manual seats
My Journal
Jump to top BTB is offline   Reply With Quote
Old Thu, Dec-13-2018, 08:01:19 PM   #9459
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Reputation: 0 Speed Monkey is on a distinguished road
I have a ho-hum entry... The passenger front "OG" 547R wheel developed a crack at the base of one of the spokes on the split spoke design. I bought a replacement for a grip of cash from HRE! Now, I can race around win my hair on fire without worrying that my front wheel will disintegrate and then putting me in a ditch. Frankly, I don't need any help in finding ditches; I'm capable of doing that unassisted! Hah!
Jump to top Speed Monkey is offline   Reply With Quote
Old Thu, Dec-13-2018, 11:25:07 PM   #9460
CSLM3Wannabi
Reputation: 0 CSLM3Wannabi is on a distinguished road
Almost finished!!!
Thinking I prefer the smoked corner lenses that were on before I gave the body shop the new OEM ones I bought...
Mmmmm. Nardo!
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Jump to top CSLM3Wannabi is offline   Reply With Quote
Discussing What did you do to/for your ///M today? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
