Old Fri, Aug-31-2018, 11:51:24 PM   #971
M3jv909
Reputation: 0 M3jv909 is on a distinguished road
Default Re: SMG troubleshooting FAQ
Could my slave cylinder be out? Just discovered this today, car doesn't start, leaked all pentosin out
Sent from my SM-G935T using Tapatalk
Jump to top M3jv909 is offline   Reply With Quote
Old Sat, Sep-01-2018, 07:47:35 AM   #972
zivagolee
@zivagolee
Reputation: 0 zivagolee is on a distinguished road
Maybe clutch actuator. If it's the part that's connected to the gear position sensor, then likely it.
2003 Orient Blue M3
https://www.instagram.com/zivagolee
Jump to top zivagolee is online now   Reply With Quote
Old Fri, Oct-26-2018, 11:23:11 PM   #973
ultimatemj
Reputation: 0 ultimatemj is on a distinguished road
Thatís what happened when my slave blew...
2004 JB/Blk SMG | 2nd owner | Purchased in 2008 w/24k miles
Key maintenance done: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ : Evolve airbox | Supersprint Exhaust | PE tune | CSL trunk | 18Ē VMR 710 w/PSS | EU OE 2pc Rotors | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Jump to top ultimatemj is offline   Reply With Quote
Old Tue, Feb-05-2019, 05:38:06 PM   #974
Rickyrosh
Reputation: 0 Rickyrosh is on a distinguished road
Need some insight on this issue. Have not puled codes yet; plan to take it to my Indy shop tomorrow. This morning the SMG light (Amber) came on and car shifted a little slower into R and 1st, then when in 4th the revs would not go past 2k. Dropped it to 3rd and revs up fine to 3k. Didnít want to push it further since car was not up to temp. The car hadnít been started in a week. (04 conv with 116k, new clutch and flywheel 2k miles ago.)
Appreciate any inputs on the cause. Hope to drive slow in 3rd to Indy shop tomorrow.
Jump to top Rickyrosh is offline   Reply With Quote
Old Thu, Feb-07-2019, 05:29:17 AM   #975
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Could be losing pressure and that is why there is latency in shifting in addition to other issues. Until you get the codes, it would be difficult to ascertain what is failing.
2016 M235i - Black on Black
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Thu, Feb-07-2019, 10:57:00 PM   #976
Rickyrosh
Code for position sensor P1848 and causes code P1756 to show up. Essentially car went into limp mode. SMG acting really weird - stays in N, restart car then able to shift to 1 and R, another restart wonít shift out of N. Pump and fluid are fine.
Old Sun, Feb-10-2019, 04:03:56 AM   #977
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
Any up to date links for the SMG.pdf file?
Jump to top Aeko is offline   Reply With Quote
Old Tue, Feb-12-2019, 05:36:01 PM   #978
IggyP
Reputation: 0 IggyP is on a distinguished road
2004 M3 with 120k miles.
I had an issue of my SMG dropping out of gear when it was supposed to be downshifting and SMG cog light would also light up with code P1717.
It would drop out of gear for 1 second, then go back in and I could continue driving like nothing ever happened.
I changed my relay and that didnt help. Next I checked the fluid level on the expansion tank right next to the intake manifold. I found that my fluid is low.
Realizing that it is obviously leaking somewhere, I saw that my pump is covered in the green Pentosin oil.
Upon further inspection the leak is coming from the house and fittings. It is known as the SMG hose. It goes from the expansion tank into the pump.
Since I topped off the fluid I dont have anymore dropping out of gear issues and I have not had any SMG lights on the dash.
I spent a lot of time researching what it could have been. From the temperature sensor, to the actuator, to the gear position sensor. My advice is to start from the lowest cost option and work your way up. My issue is leaking fluid and a $26 hose from BMW.
edit. My issues started when we had a week of -20 degree temperatures in Chicago area. I'm guessing old age and these crazy Hot + Cold temperatures here cracked all the old plastic pieces and ruined the o-rings.
Jump to top IggyP is offline   Reply With Quote
Old Tue, Feb-12-2019, 06:31:03 PM   #979
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
I'd beg to differ with that, the best route is to diagnose the issue and then repair it. Throwing parts at any problem and hoping you luck into the repair at some point really isn't a cost effective way to fix anything.
2002 AW M3
Jump to top brichter is offline   Reply With Quote
Old Tue, Feb-12-2019, 07:06:40 PM   #980
IggyP
Not so easy to diagnose these SMG problems. I was convinced it would be the Gear position sensor for the longest time. I read the first 30 pages of this SMG troubleshooting thread and not a single person spoke about replacing this reservoir hose. Took some digging.
faq, smg, troubleshooting
Troubleshooting Codes AirDoc E36 M3 (1992-1999) 0 Sat, Nov-17-2007 04:49:53 AM
Troubleshooting a problem ----> HELP ! RoadShreader E36 M3 (1992-1999) 43 Sun, Dec-31-2006 08:05:57 PM
Eclipse Troubleshooting crazy32184 E36 M3 (1992-1999) 7 Thu, Jun-09-2005 08:03:15 AM
HELP PLEASE!!! Troubleshooting my ///M! M3nEwBoOtY E36 M3 (1992-1999) 6 Sun, Apr-03-2005 05:37:52 PM
Discussing SMG troubleshooting FAQ in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
