Old Tue, Sep-05-2017, 01:13:33 AM   #41
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Re: Koyo radiator experience?
Ok I was looking at the CSF stuff but I think I just got talked out of it. What about oil coolers. What do you guys like for these?
Jump to top Engrmikl is offline   Reply With Quote
Old Tue, Sep-05-2017, 12:29:57 PM   #42
M3AT
Reputation: 0 M3AT is on a distinguished road
I finally got mine installed, so wanted to add my impressions of the koyorad as well. As stated above the install was smooth as could be, locked into the notches just like stock. I needed to find some bolts to mount the oil cooler but other than that fitment was 100%. I deleted my mechanical fan and all my shrouds to run a spal, so I can't comment on the shroud fitment with the radiator, but I was very impressed with the fit and finish. Took it to mid ohio last weekend, weather was only in the mid sixties to 70, but the coolant gauge never went past the middle. I know that temp isn't a strenuous test, so I look forward to seeing how it does in hotter weather, but so far I'm extremely impressed with this radiator and would recommend it to anyone!
Jump to top M3AT is offline   Reply With Quote
Old Tue, Sep-05-2017, 01:06:11 PM   #43
Move_Over
Reputation: 0 Move_Over is on a distinguished road
I'm not sure the CSF is as evil as people think, at least in my case. I took a hard drive yesterday after a bleed/rebleed/triplebleed at 97 degrees and my temps were rock solid at 168F (I have a water temp sensor at the block, not the oem water temp sensor). I am driving Sebring this weekend (if Irma leaves me alone) so I will have a better track experience with the CSF radiator.
I think the kicker is the bleeding. But, that's my .02.
Jump to top Move_Over is online now   Reply With Quote
Old Tue, Sep-05-2017, 02:40:50 PM   #44
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
Originally Posted by Move_Over View Post
Tunersports has them on sale now for $387 shipped, so I ordered one.
I was going to stick with the OE radiator (getbmwparts has them for only $282), but the NPT port on the Koyorad was the selling point for me.
04 E46 M3
17 WK2 GC
01 E46 325iT
Jump to top elbert is offline   Reply With Quote
Old Tue, Sep-05-2017, 02:55:46 PM   #45
M3AT
Unless that vendor has added the NPT port on their own, the Koyo doesn't have one.
Old Tue, Sep-05-2017, 02:58:28 PM   #46
Drewster
Drewster's Avatar
...there is no NPT port on the Koyorad.
Old Tue, Sep-05-2017, 03:44:29 PM   #47
elbert
Sikkens Autocryl MM
elbert's Avatar
Wales
Hmm, this was the description, but since you have one I would obviously take your word over theirs
Koyo HH Series Radiator HH422675 for a 2001 2002 2003 2004 2005 2006 BMW 3-Series E46 M3 (M3 only) (E46 Chassis - w/ All Transmission) .
Features
Koyorad “HH” Series 48mm Hyper Core
OE Specific mounting and direct fit
Nocolok-R Brazing
Precise Tube and Fin alignment
Billet aluminum filler neck
1/8” NPT female accessory fitting
I guess we'll find out!
04 E46 M3
17 WK2 GC
01 E46 325iT
Old Tue, Sep-05-2017, 03:51:04 PM   #48
Drewster
Drewster's Avatar
Bummer.. where's that description? Koyo's website makes no mention of it, nor is it on Amazon - would probably be good to get that vendor to update their description
http://koyoradracing.com/products/ra...s.asp?make=BMW
Old Tue, Sep-05-2017, 05:42:14 PM   #49
elbert
Sikkens Autocryl MM
elbert's Avatar
Wales
It was on the vendor's website (Tunersports). Oh well.
04 E46 M3
17 WK2 GC
01 E46 325iT
Old Tue, Sep-05-2017, 06:00:58 PM   #50
Engrmikl
Sooooo
Basically CSF or Toyo I should be good.
Anyone have an opinion on 100k service for the oil cooler. Clean or replace? If replace who do you like for a drop in unit besides OE
Discussing Koyo radiator experience? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
