Old Wed, Aug-02-2017, 12:04:49 AM   #21
M3AT
Reputation: 0 M3AT is on a distinguished road
Default Re: Koyo radiator experience?
My M3 does the same going up hill under load now with the Electric Fan, didn't do this with the Mechanical Fan.
Look at LAWlence's fan mounting bracket.
http://N15 Design E46 M3 Electric Fa...5&share_type=t
Thanks for the tip, but the link didn't work for me :/
Jump to top M3AT is offline   Reply With Quote
Old Wed, Aug-02-2017, 12:12:14 AM   #22
Move_Over
Reputation: 0 Move_Over is on a distinguished road
Originally Posted by M3AT View Post
I checked my radiator and the inlet path is totally clear with no blockage.
I think the exit port was the one in question a few years back with the CSF.
Jump to top Move_Over is offline   Reply With Quote
Old Wed, Aug-02-2017, 12:21:50 AM   #23
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Sorry, fixed it.
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - Turner Spacers 15/12 - BWS 500S 11k/15k
Old Wed, Aug-02-2017, 12:22:31 AM   #24
M3AT
The outlet path looks clear as well, sorry for lack of clarity
Old Wed, Aug-02-2017, 12:41:59 AM   #25
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Koyorad Radiator
http://www.m3forum.net/m3forum/showt...yorad+Radiator
Originally Posted by hemi8 View Post
Finally installed an all aluminum radiator, went with a Koyorad. The fit was dead-on perfect, nice welds, excellent quality, cools beautifully. Highly recommend.
Originally Posted by Joefresh View Post
I have had nothing but good results with koyorad aluminum radiators in my cars. if koyo prices the e46 m3 radiator like they do their other products it shouldnt be much more than OE bmw radiator.
to me thats a no brainer but i have experienced their product on my other vehicles which were turbo.
might be over kill but thats my style
Originally Posted by Treflip View Post
Another happy Koyorad user here too. I've had mine in for over a year without a single hiccup. Highly recommended.
Koyorad is pleased to introduce a high quality direct replacement all aluminum performance radiator for 2001 through 2006 BMW M3 E46 chassis. This application features Koyorad's “HH Series” high density, two row 48mm radiator core which was developed to increase coolant volume, promote proper air flow and coolant circulation. In typical fashion, Koyorad has engineered this radiator with precision, directly replacing the stock OEM plastic/aluminum radiator and will bolt easily to the factory equipped fan shroud for a quick and simple installation. Koyorad’s superior quality, precision hand welds, reliability and uniformity are what have earned Koyorad their excellent reputation in performance cooling worldwide.
All radiators are fully polished to a mirror finish. Each feature the following:
- Provides 20% to 30% more cooling than standard radiators
- Handles high revving, high performance motors
- Perfect for Turbocharged, Supercharged & Nitrous Oxide equipped engines
- Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed (no epoxy)
- Koyo is on the cutting edge of technology and design with Japan's largest automobile manufacture
- Custom built OEM fit - All radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used. This ensures proper fit, just like your original equipment! Koyo builds radiators to fit today's most popular import performance cars.
Price went up from $422 to $436.
Old Wed, Aug-02-2017, 12:51:12 AM   #26
djjvr
OEM+
djjvr's Avatar
Denmark
I would just leave the AUX Fan as it flows way more air than the Mishi Fan.
This is true, I may just make the DME adjustments and leave it at that until there's a problem, or wire the Mishi up as a secondary.
"Sucking at something is the first step to being sorta good at something!"
Build Journal Instagram
Old Wed, Aug-02-2017, 02:58:35 AM   #27
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
I'm running the Aux Fan with a Mishi mounted inside the stock fan shroud. It works good in stop and go traffic but on the highway under load it starts to heat up. That's in Vegas heat of 110+ thou.
Old Wed, Aug-02-2017, 04:32:32 AM   #28
speeeding
Reputation: 0 speeeding is on a distinguished road
I am in a similar position to the OP, and I posted this thread with all the options currently available. http://www.m3forum.net/m3forum/showthread.php?t=590565
I was also leaning toward the Koyorad, but it seems that the periodic hot-running sessions can't be avoided, even with the best kits out there. So it makes me think the stock unit is still pretty darn good. Plus, the prices have risen on the Koyo, which makes it a bit less attractive in terms of value.
Also, all radiators will eventually accumulate gunk and debris on the outside, so I'm more inclined to replace a cheap(er) stock unit than an expensive aftermarket piece.
Jump to top speeeding is offline   Reply With Quote
Old Wed, Aug-02-2017, 04:33:25 AM   #29
djjvr
OEM+
djjvr's Avatar
Denmark
To be fair nothing should be alive at that point...
Kidding. How are you managing the fan speed of the Mishi?
Old Wed, Aug-02-2017, 07:24:15 AM   #30
silaciM3CS
Reputation: 0 silaciM3CS is on a distinguished road
Exactly. So many had alread failed at even matching the OE performance and later on made revisions to "fix" it.
Koyo is still well priced anf a highly regarded brand, but we need more accurate feedback to judge its performance, possibly from those tracking it and who otherwise had problems with a fresh OE rad keeping up.
Jump to top silaciM3CS is offline   Reply With Quote
Discussing Koyo radiator experience? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
