Old Sat, Aug-06-2016, 05:28:55 PM   #31
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Default Re: S54 Vanos Info Thread
Originally Posted by Eduki View Post
This is awesome! Thank you so much for sharing!!
Welcome...
Old Sun, Aug-14-2016, 12:50:58 AM   #32
twlsfm
Reputation: 0 twlsfm is on a distinguished road
I finally did this and the car is running great! This thread is great!
One note I would like to add. I ran into one thing that could have been really bad.
Something I noticed when doing all of this was that my crank pin was not all the way inserted when I thought it was!!!! It seemed like it was in but wasn't. What i had to do was as i was rotating the crank put pressure on the crank pin. You will then feel a very nice interaction of the crank pin and crank itself at TDC.
If you are not sure, see how far the pin sticks out when you KNOW its not in the right spot.
I made a vanos success story thread.. to many bad ones.
http://www.m3forum.net/m3forum/showt...post1067477776
- Structural Foam Applicator Gun for rent
- Eastwood Fender Roller for rent
- Airbag reset and peak code reader for rent
Jump to top twlsfm is offline   Reply With Quote
Old Sun, Aug-14-2016, 05:09:03 PM   #33
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Awesome
That's a good point as I experienced this as well. I used a mirror to look down and see exactly where the mark was on the flywheel then insert the tool. I will add this info above.
Old Sun, Aug-14-2016, 09:24:42 PM   #34
DanFromTucson
Reputation: 0 DanFromTucson is on a distinguished road
I'm going through my VANOS rebuild and rattle repair this weekend. I ran into 2 problems that make me think something might be wrong.
First, it was really hard to get my exhaust sprocket back on after I replaced the upper timing chain guide. There just wasn't much slack in the chain. I finally did get it on using a clamp.
Then I went to reinstall the tensioner. I can't get the tensioner deep enough into the hole to get the threads to engage. Even pushing with all my might to get the tensioner to collapse, I can't get it in far enough to start the threads.
Did something go wrong? Any advice would be appreciated.
Jump to top DanFromTucson is offline   Reply With Quote
Old Sun, Aug-14-2016, 10:00:20 PM   #35
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Are you sure the chain didn't move while you had the exhaust sprocket off? Did you clamp it on the intake sprocket like in the photo above?
Is the crankshaft Pin still in place?
Try cleaning the tensioner with brake cleaner, it might just be really stiff.
Old Sun, Aug-14-2016, 11:43:18 PM   #36
DanFromTucson
Edit
Rajaie from Beisan Systems helped. I had the upper timing chain guide slid under the lower timing chain guide. That was the problem.
While I was reinstalling the tensioner bolt though (10 MM hex), I *snapped* the bolt. I was using a torque wrench set to 30 NM, so I have no idea how I did that.
Now I have to figure out if there is a way to remove the broken portion of the bolt, or if I have to have my car towed somewhere. I feel terrible. Let me know if anyone has any suggestions. There is only about 1 MM of the broken bolt sticking out of the head, so I can't get vice grips on it.
Old Mon, Aug-15-2016, 12:25:22 AM   #37
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Rajaie is so awesome, helping out on a Sunday! Glad to hear you figured out what was wrong. Sorry to hear about breaking the bolt. What's funny is I almost snapped the same one!
Can you take some pictures and post them? Maybe we can get a better idea of what you are dealing with and come up with some ideas to get that sucker out.
Old Mon, Aug-15-2016, 03:34:40 PM   #38
DanFromTucson
Here's a picture. The broken bolt is circled. The clearance isn't great. This is on a Z4M coupe, so there is less clearance in front of the engine. I don't know if I could get a drill in there to try a left-hand bit and extractor.
Old Mon, Aug-15-2016, 04:09:23 PM   #39
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Default S54 Vanos Info Thread
Ya that is pretty tight. I don't think you could get a right angle drill in there either. I first thought you broke the head of the bolt off. I have some Craftsman bolt extractors that work great in situations like this but I'm not sure if there is enough of the bolt sticking out.
Here is a kit for $18- http://www.sears.com/craftsman-bolt-...000P?rrec=true
#2 Remover fits Hex sizes 5/16 in. and 8mm
#4 Remover fits Hex size 10mm
#8 Remover fits Hex size 13mm
#12 Remover fits Hex size 11/16 in.
#13 Remover fits Hex sizes 3/4 in. and 19mm
Old Mon, Jan-23-2017, 09:20:44 PM   #40
Thenakedflyer
Reputation: 0 Thenakedflyer is on a distinguished road
United Kingdom
Hello guys.. I'm doing a whole engine rebuild and at stage of doing the timing check on the vanos. I followed the beisan systems procedure both shafts and crank locked and after tightening everything, then, doing a full rotation and then checking the timing again, the inlet camshaft was in a retarded position by about ten degrees or so so had to slacken the hub bolts again and turn the shaft back to the correct position and retighten the hub bolts.. This was after the whole vanos unit had been fully mounted. Am I right in saying that after a few full cycles or rotations of the assembly and back to tdc cylinder one the splined shafts should be fully towards the front of the car and against the vanos unit and oil pump disc ie against the piston stops and the camshafts still be in time with the bridge and locking pins dropping in?
Jump to top Thenakedflyer is offline   Reply With Quote
beisan, turbo toy, vanos
Discussing S54 Vanos Info Thread in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
