Old Thu, May-05-2016, 11:46:44 PM   #21
soundmasterx
Reputation: 0 soundmasterx is on a distinguished road
Default Re: One Stop S54 Vanos Info Thread!
Wow sounds like you have some work to do. Nice upgrades! Remember to stuff rags down inside the timing chain area so you don't drop bolts or tools down inside the engine. Also when you set your timing, crank the engine by hand several times to make sure nothing is binding before starting the car. Good luck to ya!
Oh yea lots to do. thanks again!
Sent from my VS985 4G using Tapatalk
RE-AKG-CPI-TTFS-Eibach-Apex Arc8-Geoff-Beisan Vanos Overhaul-Turner Subframe Reinforcement-4.10 R&P-Megan Racing
335hp@7500rpm
261tq @5500rpm
Next stop, Turbo Town!
Jump to top soundmasterx is offline   Reply With Quote
Old Mon, May-09-2016, 03:01:31 AM   #22
twlsfm
Reputation: 0 twlsfm is on a distinguished road
Wich procedure should be done first… Vanos or valve adjustment? I plan on doing them at the same time. Does it matter?
Jump to top twlsfm is offline   Reply With Quote
Old Mon, May-09-2016, 03:53:57 AM   #23
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Not sure if it matters but I did my Vanos first then the Valve adjustment. Do the Intake side first then the Exhaust side.
Here is a blank forum you can print up to keep track of the valve adjustments.
http://www.m3forum.net/m3forum/showthread.php?t=510023
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - Turner Spacers 15/12 - BWS 500S 9k/11k
Old Mon, Aug-01-2016, 12:41:03 AM   #24
twlsfm
Default Re: S54 Vanos Info Thread
Just did all this today.. Little worried about the timing. I am pretty sure I did everything correctly. How much drag is there suppose to be when you rotate the crank? It seems free to rotate and then gets to where it seems like it's going over a hump and then is easy to move. I have rotated the engine several times and timing seems to be ok.
- Structural Foam Applicator Gun for rent
- Eastwood Fender Roller for rent
- Airbag reset and peak code reader for rent
Old Mon, Aug-01-2016, 01:38:09 AM   #25
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
There is some resistance as it comes around to TDC. I cranked the engine by hand a few times and rechecked the timing. I was so OCD I did this several times to make sure the timing was ok before starting the engine.
Old Mon, Aug-01-2016, 01:50:45 AM   #26
twlsfm
This is more then just Tdc resistance. It seems like as it starts to depress a valve that there is added resistance.
Old Mon, Aug-01-2016, 01:57:28 AM   #27
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
There's some resistance but you shouldn't have to really crank on if you understand what I'm saying.
Read this thread- http://www.m3forum.net/m3forum/showthread.php?t=551993
Old Mon, Aug-01-2016, 03:51:29 AM   #28
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
Fantastic thread! Just did this the entire beisan kit the last couple days! I wish I would have found this thread first. The vidoes are a great addition.
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Tue, Aug-02-2016, 02:07:22 AM   #29
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Thanks!
Old Thu, Aug-04-2016, 02:38:57 AM   #30
Eduki
Eduki's Avatar
Reputation: 0 Eduki is on a distinguished road
Spain
This is awesome! Thank you so much for sharing!!
Jump to top Eduki is offline   Reply With Quote
beisan, turbo toy, vanos
Discussing S54 Vanos Info Thread in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
