Old Sun, Mar-06-2016, 04:33:45 PM   #11
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Default Re: One Stop S54 Vanos Info Thread!
Reynal20 PM Sent...
Originally Posted by TC2 View Post
I appreciate the work you put into compiling this information but, I must say, I am against Comic Sans.
Changed....
Old Mon, Mar-07-2016, 03:22:33 AM   #12
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
Reputation: 0 dtmpowerjc is on a distinguished road
Did mine this weekend with kidrobot, he did an awesome job I'm still putting car back together but after we were done it fired right up and numbers look okay on vanos test.
Zep industrial cleaner did a great job cleaning the parts lol.
Jump to top dtmpowerjc is offline   Reply With Quote
Old Mon, Mar-07-2016, 06:13:01 PM   #13
albino09
A Yankee South of the Mason-Dixon
Thanks for this! Glad I could contribute a small amount with that excel parts list
1997 318i Silver/Black...Daily
Old Mon, Mar-07-2016, 06:43:06 PM   #14
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Welcome and Thanks for the parts list.
Old Tue, Mar-08-2016, 05:56:49 PM   #15
R_Machine
Reputation: 0 R_Machine is on a distinguished road
This is a very commendable piece of work. Thank you for taking the time and effort to put this together!!! Very much appreciated.
Jump to top R_Machine is offline   Reply With Quote
Old Sun, Mar-20-2016, 04:38:32 PM   #16
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Thank You...
Old Thu, May-05-2016, 01:40:14 PM   #17
soundmasterx
Reputation: 0 soundmasterx is on a distinguished road
Thanks OP this is a great thread! Is it really necessary to purchase all the parts on the spreadsheet? All the vanos rebuilds/refresh I've seen they usually just buy the beisan parts and hub (If needed). Is it a bad idea to replace only the beisan parts and hub? Should I not reuse any parts listed on the spreadsheet? Sorry if these are dumb questions, I just wasn't aware so much needed to be replaced for the vanos rebuild. Thanks again!
RE-AKG-CPI-TTFS-Eibach-Apex Arc8-Geoff-Beisan Vanos Overhaul-Turner Subframe Reinforcement-4.10 R&P-Megan Racing
335hp@7500rpm
261tq @5500rpm
Next stop, Turbo Town!
Jump to top soundmasterx is offline   Reply With Quote
Old Thu, May-05-2016, 09:57:05 PM   #18
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Thanks, glad to help out. I would recommend everything on the list. The hub and sprocket bolts from Lang Racing are $22 shipped. The bolts are easy to change while your in there and have been known to break. The chain guide is a must, mine was broken just like most are. If you car is running good you can take the Beisan solenoid valve off the list ($150) as it's easy to change later if it goes bad. Depending on the mileage of your car you can reuse the VCG per Rajaie from Beisan. I just did mine and I have 107K and the VCG looked great. If you decide to get a new one go with an OE BMW VCG. The Elring gaskets have been known to leak.
I have the complete S54 Timing Tool Kit if you need it.
Old Thu, May-05-2016, 10:14:50 PM   #19
soundmasterx
Bro... You're f'n awesome. I purchased the Lang bolts last month along with the valve tool so I'm good with that. I just broke 100k and I'm hearing a new noise at the 3500rpm-4000rpm range... I figured I'd rip the vanos apart assuming that is the culprit and it wouldn't hurt to refresh it anyway. I've got new eibach suspension, 4.10 r&p, full csl convert, rear subframe reinforcement, headers sec 1,2 and 3, power pulleys and a few more odds and ends in my room waiting for me to put them on. Iots to do, may as well do It at the same time. Thanks again for the help!
Sent from my VS985 4G using Tapatalk
335hp@7500rpm
261tq @5500rpm
Old Thu, May-05-2016, 11:33:50 PM   #20
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Default One Stop S54 Vanos Info Thread!
Wow sounds like you have some work to do. Nice upgrades! Remember to stuff rags down inside the timing chain area so you don't drop bolts or tools down inside the engine. Also when you set your timing, crank the engine by hand several times to make sure nothing is binding before starting the car. Good luck to ya!
beisan, turbo toy, vanos
Discussing S54 Vanos Info Thread in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
