Old Wed, Jun-03-2015, 03:49:15 PM   #31
MartynT
MartynT's Avatar
United Kingdom
Default Re: MSS52 / MSS54 / MSS54HP Binary Modification Tool
Originally Posted by SliM3 View Post
Martyn,
The MAP scaling information is incorrect. I meant to post a while back, but I actually went through all the disassembly subroutines related to CSL mass air and MAP, linked them together, and ultimately concluded that the MAP scaling is indeed mbars and not volts per bar.
Basically the gist of the operation is this:
  • A scale is created using HFM initial airmass (converted from kg/h to mbar, across all cylinders per 720-degrees) and the mbar value in the MAP scale; ie. 5 to 1050mbar = 0-5volts (which then becomes an analog/digital (AD) count using 512/1023 calculations)
  • The MAP sensor voltage is then sampled via the AD Converter and an associated AD count is populated. This AD count is then compared to the above scale to provide the corrected MAP value.
  • The offset makes a correction based on the specific MAP sensor circuitry to the point where voltage output will become linear. Basically fine tunes the output so there's no deviation between the sensor and the linear AD converter.
There's a little more going on behind the scenes but the above example is pretty much what's happening. The mbar conversion math for the MAP scale is x/32.
Bugger!
So the following values are no good?
76C0 0C80 0C80 8340 - GM 1 Bar MAP sensor
9A70 0026 0C80 9600 - Stock CSL MAP sensor
Cheers,
Martyn
Jump to top MartynT is offline   Reply With Quote
Old Wed, Jun-03-2015, 03:57:32 PM   #32
MartynT
MartynT's Avatar
United Kingdom
Originally Posted by ice.blade View Post
example this one, remove .doc
Thanks, found the issue. Will upload a new build later this eve.
Old Wed, Jun-03-2015, 04:00:50 PM   #33
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
Nice faq Martyn.
One minor typo or verbiage clarification...
Originally Posted by MartynT View Post
Q: Will this effect my tune from 'tuner x'?
A: If you're able to get a legit read from your ECU/DME that isn't encrypted or scambled then yes. The tool won't touch any other parameters in your tune so your tune will not be effected.
I think you obviously either mean to say
"will this work with my tune" = Yes or
"will this negatively effect my tune" = No
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Wed, Jun-03-2015, 04:05:13 PM   #34
MartynT
MartynT's Avatar
United Kingdom
Originally Posted by geargrndr View Post
Nice faq Martyn.
Fixed, thanks
Old Wed, Jun-03-2015, 04:07:23 PM   #35
MartynT
MartynT's Avatar
United Kingdom
bug alert Ill try this latest 1.4.2 tool but when I load anyone MSS52 partitial tool crash if I load MSS52 full than partitial works fine
old 1.1 ver works excelent
Now fixed in 1.4.3 which is available to download.
I've disabled MAP sensor swapping until I receive clarification from Sli.
Old Wed, Jun-03-2015, 04:38:34 PM   #36
SliM3
SliM3's Avatar
Bugger!
Cheers,
Martyn
8340 0078 0C80 8340 - GM 1 Bar MAP sensor
(1050mbar / 120mbar / 100mbar / 1050mbar)
Stock CSL is good to go.
Old Wed, Jun-03-2015, 05:03:34 PM   #37
Mackie
Reputation: 0 Mackie is on a distinguished road
Version 1.4.3 still crash on mine. Version 1.1 is fine.
Jump to top Mackie is offline   Reply With Quote
Old Wed, Jun-03-2015, 05:05:48 PM   #38
MartynT
MartynT's Avatar
United Kingdom
Mackie, please send me your bin so I can see what's up.
Cheers
Old Wed, Jun-03-2015, 05:06:37 PM   #39
MartynT
MartynT's Avatar
United Kingdom
Cheers
Old Wed, Jun-03-2015, 05:31:08 PM   #40
MartynT
MartynT's Avatar
United Kingdom
Now fixed in 1.4.4.
Discussing MSS52 / MSS54 / MSS54HP Binary Modification Tool in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
