Old Fri, May-22-2015, 09:19:03 AM   #11
MartynT
MartynT's Avatar
United Kingdom
Default Re: MSS52 / MSS54 / MSS54HP Binary Modification Tool
Hi Jozy,
KF_TZ_MIN is set to -10 seemed, it seemed to be the sweet spot.
Cheers,
Martyn
Jump to top MartynT is offline   Reply With Quote
Old Fri, May-22-2015, 03:51:41 PM   #12
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
This is super duper cool.
I see n00bz0rz getting into fun trouble w/ their motors and potentially state inspections with this tool....
...but hey, not my problem. This is super great for those who know what they are doing.
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Sat, May-23-2015, 01:50:44 PM   #13
smooth11981
Reputation: 0 smooth11981 is on a distinguished road
Excellent.
Jump to top smooth11981 is offline   Reply With Quote
Old Tue, May-26-2015, 05:50:07 PM   #14
PhenielG01
Reputation: 0 PhenielG01 is on a distinguished road
Originally Posted by MartynT View Post
Thanks to the power of this forum and its users (Terra, P0lar, Smooth, Tap, SliM3 et al) , I've learnt a great deal about the DME in our cars. I used this information to write a PHP based website that allowed users to upload the dumps taken from their DMEs using Smooth's fantastic BMWFlash and modify them without need for any hex editing.
After processing over 2500 binaries I decided that an offline version should be my next project.
This lead me to write this:
My tool allows for the following changes:
- 155MPH Limiter removal
- SMG Style Shift lights on 6 Speed Manual cars
- Sport memory
- Dyno limit removal
- Increase rev limiter
- CSL SMG Shift / Rev matching + Inertia fix
- Disable secondary air pump
- Enable burble and pop on over run / lift off (Childish but some love it)
- Disable fault code / check engine light for physical removal of the secondary air pump
- Disable fault codes / check engine light for cat deletes
- EWS delete
- Comfort throttle map adjustment
- Sport throttle map adjustment
- Warm up light changes
- Checksum correction
If you're too lazy or don't have the skills to edit the hex, grab yourself a FTDI based USB OBD cable, a copy of BMWFlash or Paffy's MSSFlasher, take an ECU dump and edit with my tool and then flash back
Grab a copy from here: http://www.mss54.info/tools/ - .NET Framework 4.0 is required, as is a Windows PC obviously
Cheers,
Martyn
Hello MartynT, where can I get a hold on bin files for M3's?
Jump to top PhenielG01 is offline   Reply With Quote
Old Tue, May-26-2015, 08:02:14 PM   #15
MartynT
MartynT's Avatar
United Kingdom
You download it from your ECU using BMWFlash or MSSFlasher and edit it by hand or with my tool.
Cheers,
Martyn
Old Tue, May-26-2015, 08:12:29 PM   #16
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Martyn, Thats amazing Mate. Thanks so much for doing this for the community.
Old Thu, May-28-2015, 05:36:35 PM   #17
95bullet
95bullet's Avatar
Reputation: 0 95bullet is on a distinguished road
Thanks for doing this for the community. Do you know if the cat delete option completes the readiness monitor as well?
Jump to top 95bullet is offline   Reply With Quote
Old Thu, May-28-2015, 06:05:45 PM   #18
MartynT
MartynT's Avatar
United Kingdom
The cat delete option simply '00's the 13th byte for the cat effeciency DTC for both secondary lamdas. One of the other guys may be able to tell you if this is sufficient for the readyness check to pass. If it's not, it's something I can implement without too much hassle.
Cheers,
Martyn
Old Thu, May-28-2015, 11:50:37 PM   #19
LAWLence
N15 Design
Reputation: 0 LAWLence is on a distinguished road
Idle RPM would be another good one to add. That was something I changed when I got some buzzy engine mounts!
Jump to top LAWLence is offline   Reply With Quote
Old Mon, Jun-01-2015, 08:34:30 PM   #20
MartynT
MartynT's Avatar
United Kingdom
Ok guys, I'm just testing a new build containing the following changes:
- SMG Final Drive Swap
- Transmission Swap (Including SMG related DTC delete / additions)
- CSL Intake Flap Delete
I've also scaled the app slightly to work better on lower resolutions and allow room additional features.
Can anyone hook me up with the MAP and IAT scaling figures for the commonly used sensors?
Cheers,
Martyn
Discussing MSS52 / MSS54 / MSS54HP Binary Modification Tool in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
