Old Thu, Oct-27-2016, 07:42:49 PM   #291
midnighted
Reputation: 0 midnighted is on a distinguished road
Default Re: Review 996 Porsche 911 Brembo Brakes Installed!
Originally Posted by SYRARCH04 View Post
I have the same set up as dafoe, with drilled rotors in the front. If I do some track days next summer should I swap the rotors for blanks? I know generally drilled rotors are more likely to fail (crack at the holes) so track guys tend to stay away, but wondering if it's a given and true safety concern, or can I just use these up and get blanks when I need new ones.
I didnt think anyone sold CSL size blanks? I know PFC has their Direct Drive slotted rotors but they have been on back order for the past year now.
Jump to top midnighted is offline   Reply With Quote
Old Thu, Nov-10-2016, 07:13:52 PM   #292
nemesys6
Reputation: 0 nemesys6 is on a distinguished road
Would you recommend getting a caliper rebuild kit if getting used calipers?
http://www.partsgeek.com/gbproducts/...ad=47433965052
Jump to top nemesys6 is offline   Reply With Quote
Old Thu, Nov-10-2016, 08:27:47 PM   #293
SWRTstang_M3
Custom X
SWRTstang_M3's Avatar
Reputation: 0 SWRTstang_M3 is on a distinguished road
It's recommended that you do, you don't want to go through the entire process of machining, powder coating, installing, bleeding and so on just to find out you have a faulty seal and/or boot.
  • M3 SMG (Stock) MartynT Tool SAP Delete TMS Power Pulley Kit TMS RSM Koni 1140 Sport Suspension Kit Powerflex Race Differential Bushings (F&R) ECS 80A Transmission Mount Set ECS RST Reinforcement Plates Michelin PSS Depo Smoked Corners
Jump to top SWRTstang_M3 is offline   Reply With Quote
Old Fri, Nov-11-2016, 12:40:45 AM   #294
creature_healer
Reputation: 0 creature_healer is on a distinguished road
Sexy and functional
Jump to top creature_healer is offline   Reply With Quote
Old Fri, Nov-11-2016, 09:08:52 PM   #295
Chrisandaivi
Reputation: 0 Chrisandaivi is on a distinguished road
If i do get these calipers, will it fit OEM square 18's??
Jump to top Chrisandaivi is offline   Reply With Quote
Old Sat, Nov-12-2016, 04:38:44 AM   #296
UdubBadger
UdubBadger's Avatar
Reputation: 0 UdubBadger is on a distinguished road
Yes that's what I ran too
2004 E46 ///M3 IR/IR 3 pedals - RETIRED 01/16
Jump to top UdubBadger is offline   Reply With Quote
Old Fri, Dec-30-2016, 12:25:20 AM   #297
flamelauncher11
E46 Fanatic
flamelauncher11's Avatar
Reputation: 0 flamelauncher11 is on a distinguished road
Nice! I'm setting aside some funds for this project. Is P0lar still around?
2009 Nissan GT-R Premium
Gun Metallic|AFE 3" Intakes|Megan Racing Exhaust|Catless Non-resonated Midpipe|Cobb AP
Jump to top flamelauncher11 is offline   Reply With Quote
Old Fri, Dec-30-2016, 01:34:49 AM   #298
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
I got my complete, ready to install set from MCORE Innovations. He sells through TTFS or you can ping him on instagram. Very happy with mine.
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Fri, Dec-30-2016, 01:44:23 AM   #299
flamelauncher11
E46 Fanatic
Good looking out!
Out of curiosity, how much did your kit run? If it's not that much more than sourcing each part individually, I may order through them.
Old Fri, Dec-30-2016, 02:12:16 PM   #300
nasieg
nasieg's Avatar
Good looking out!
I remember that it was a few hundred dollars more than sourcing everything yourself, but it is worth it IMHO. Takes a lot of time getting everything together, rebuilding and powder coating the calipers is not hard, but does take some time.
I managed to get my whole kit done for $2500 including new front and rear rotors and track pads, but like I said, it took some time and effort.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is offline   Reply With Quote
Discussing Review 996 Porsche 911 Brembo Brakes Installed! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
