Old Wed, Mar-18-2015, 04:46:51 AM   #171
crazyseaman
chris chach
Reputation: 0 crazyseaman is on a distinguished road
Default Re: Review 996 Porsche 911 Brembo Brakes Installed!
bumping for another question,
Is there a step by step DIY for the installation of this?
I feel like at this point there would be. If so please provide me a link as ive searched for quite sometime and have not found anything.
Specific areas of interest is wiring in the pad sensor
Finally a fitment question. My front wheels are 19x8.5 et 35. I would assume like Dafoe i would also require the 5mm spacer as well?
(from post#1 his was: "My Apex ARC 8's 18x9.5 et 35 would not clear the front calipers so had to next day 5mm spacers.")
themeetspot.info
Like me on facebook for NY events, and rollout info
CHACH:
2002 E46 M3 VERT (NEW PROJECT)
1987 E30 325iS (DAILY DRIVER)
1992 DA INTEGRA (SOLD)
Jump to top crazyseaman is offline   Reply With Quote
Old Wed, Mar-18-2015, 05:06:26 AM   #172
UdubBadger
UdubBadger's Avatar
Reputation: 0 UdubBadger is on a distinguished road
Any brake install diy will do. Just attach the brackets to the caliper first and then it's same process.
GoingHAM mobile
2004 E46 ///M3 IR/IR 3 pedals - RETIRED 01/16
Jump to top UdubBadger is offline   Reply With Quote
Old Sun, Mar-22-2015, 01:57:02 AM   #173
Agent83
Reputation: 0 Agent83 is on a distinguished road
I'm going to start sourcing the 996 kit myself!
Jump to top Agent83 is offline   Reply With Quote
Old Sun, Mar-22-2015, 01:10:31 PM   #174
Roberto Ramasco
Rober Rh
Reputation: 0 Roberto Ramasco is on a distinguished road
Spain
Im doing it too, but in Spain is a little more difficult to find the brackets for install the calipers. At least I have the calipers, and the rear rotors. Im trying to buy the brackets and the front rotors on Ebay and Im waiting the four adapters from United Kingdom. I know that Rallyroad produce it too but with taxes it would be more expensive.
I will install it first of all and them I will rebuild it and paint in yellow like the ones of the first post. It looks great
Jump to top Roberto Ramasco is offline   Reply With Quote
Old Sun, Mar-22-2015, 01:47:11 PM   #175
JerseyShoreM3
E . ` ' / . F
JerseyShoreM3's Avatar
Reputation: 0 JerseyShoreM3 is on a distinguished road
Very nice!
The yellow looks great against the LSB.
Jump to top JerseyShoreM3 is offline   Reply With Quote
Old Sun, Mar-22-2015, 04:14:07 PM   #176
dafoe
dafoe's Avatar
It's the same as replacing calipers, just use the brackets from RallyRoad/P0lar. You'll need to snip some aluminum material from the rears. Just have some good metal snips, they'll do the job.
Yes, you'll need a 5mm spacer. I may have my set for sale, along with the appropriate length studs next week. The six piston Cayenne calipers are about 3mm wider than the 996 calipers.
Old Sun, Mar-22-2015, 06:35:10 PM   #177
Ribas
Ribas's Avatar
Reputation: 0 Ribas is on a distinguished road
Spain
Hi, Roberto, that sounds awesome! I dont't know anyone in spain that has done this upgrade, so plis share with us your experience! Are you posting the upgrade in another spanish forum?
Saludos!
Jump to top Ribas is offline   Reply With Quote
Old Mon, Mar-23-2015, 04:31:27 AM   #178
crazyseaman
chris chach
cool man let me know, ill take em off ur hands
themeetspot.info
CHACH:
Old Mon, Mar-30-2015, 09:25:06 PM   #179
Dstretch33
STi Driver
Dstretch33's Avatar
Reputation: 0 Dstretch33 is on a distinguished road
Very nice setup.
Flickr
Follow Automotive Dominance
Jump to top Dstretch33 is offline   Reply With Quote
Old Thu, Apr-16-2015, 04:54:12 AM   #180
jonchacon
Reputation: 0 jonchacon is on a distinguished road
After reading different threads I still have some questions...
I will be using rallyroad brake lines and front/rear brackets....I know p0lar makes some but at the time he is not available.
-front caliper machining 5mm or 5.5mm?? I can have rallyroad machine but the turn around time and shipping may be higher than my local machine shop.
-rear pad setup to avoid rust ring?
-recommended pads for aggressive street/canyon driving and potentially some light track use on a NON-DAILY spring/summer car.
Jump to top jonchacon is offline   Reply With Quote
Discussing Review 996 Porsche 911 Brembo Brakes Installed! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
