Old Fri, Apr-20-2018, 04:51:08 AM   #1
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Default The strangest oil leak
I realize that's a bold claim but damn if I'm not about to lose my mind. I've had the oil pan off twice and the transmission down once. I finally put UV dye in the oil.
There's a clear path on the rear passenger side from the lower edge of the head down the transmission to where it drips from the oil pan bolt to the floor. It's not the rear main seal or the oil pan gasket. It's not the intake or exhaust cam sensors, both are dry. It's not the timing chain tensioner bolt. There's no oil in the coolant and no coolant in the oil. Is it possible to leak oil through the head gasket without any mixing of the fluids? The valve cover gasket is OE BMW, brand new and dry all around...
Someone for the love of all that's holy please have a solution to end my suffering
Edit: Fixed, turned out to be the intake cam sensor o-ring was leaking by the back of the block.
e85 MaxPsi M3
Jump to top e46Dan is offline   Reply With Quote
Old Fri, Apr-20-2018, 05:05:06 AM   #2
bigjae1976
Default Re: The strangest oil leak
There are some freeze plugs on the backside of the head. Iíd get a mirror or a boroscope and look at that.
Assuming you ruled out the CPV.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Apr-20-2018, 05:22:40 AM   #3
e46Dan
Yes, I forgot about the CPV. It has a new viton o-ring in it. I might try the borescope with the engine running to see if it's one of the freeze plugs. Are the screw plugs for coolant passages?
Old Fri, Apr-20-2018, 05:34:31 AM   #4
E30User
Reputation: 0 E30User is on a distinguished road
This recent thread could be worth a read http://www.m3forum.net/m3forum/showthread.php?t=597459.
Jump to top E30User is offline   Reply With Quote
Old Fri, Apr-20-2018, 05:35:57 AM   #5
bigjae1976
I donít know but the freeze plugs are pressed in, not screwed.
Old Fri, Apr-20-2018, 11:38:19 AM   #6
e46Dan
I thought they could be the problem after reading that thread. I pulled the transmission and redid the rear main seal and casing for it.
If this image was a s54, the red marked would be where I can see the oil coming from. The good news is it's not the rear main or oil pan gasket.
e85 MaxPsi M3
Old Fri, Apr-20-2018, 12:02:41 PM   #7
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
There are two plugs on the head that big jai mentioned. worth checking
Jump to top schoonerm3 is offline   Reply With Quote
Old Fri, Apr-20-2018, 02:39:35 PM   #8
Texaz3
I was about to say this exact thing when I saw the picture.
Old Fri, Apr-20-2018, 03:55:46 PM   #9
PITT M3 RR
PA
PITT M3 RR's Avatar
When I was searching, one guy had a cracked oil separator that was leaking to the HG line.
Check the vanos sealing plate, oil can ride the HG protrusion straigh back and down. There’s also a bolt on the head that often backs out (per past threads) it’s hidden to the left of the thermostat housing.
Also oil return line from VC.
S54 E36 BUILD
Old Fri, Apr-20-2018, 06:39:51 PM   #10
e46Dan
The oil separator is a good thought. It does have a uv residue around it on the plastic but not much. The high pressure line on the vanos is new. I'll pop the valve cover off after work and take a look at the freeze plugs. Hopefully it's something easy and obvious.
e85 MaxPsi M3
Discussing The strangest oil leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
