Old Fri, Apr-20-2018, 07:08:05 AM   #11
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Default Re: Delete ABS
Put the fuses/rear sensors back and disconnect one of the front abs sensors. It should give you speedometer and no abs.
Sent from my Redmi Note 4 using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is online now   Reply With Quote
Old Fri, Apr-20-2018, 07:48:16 AM   #12
UFoh
Reputation: 0 UFoh is on a distinguished road
Originally Posted by PHARMDVIPER View Post
Why would you delete abs
Because ABS will try to kill you. If you aren't familiar with how to reset your ABS properly during ice mode you will go into a concrete barrier doing 100mph(at least at my local track)
I won't delete my abs because I've gotten a good habit of squeezing my brake instead of stomping em, i do much less trail braking etc. But if you have abs you will go through ice mode one day. And if you don't know what ice mode is you might literally die.
Disabling ABS is for safety purposes before anything else
Jump to top UFoh is offline   Reply With Quote
Old Fri, Apr-20-2018, 12:35:21 PM   #13
ice mode isn't really an issue on the e46, like it is on other chassis.
Old Mon, Apr-23-2018, 06:00:07 AM   #14
UFoh
As in it's not a glaring issue? It's still a thing that happens and if you don't know how to reset it you will probably have a fatal result. I happened to read about ice mode the night before it actually happened to me. I never would have known I was supposed to take my foot OFF the brake otherwise to save myself from the computer
Old Mon, Apr-23-2018, 12:52:39 PM   #15
Drewster
Drewster's Avatar
Sounds a little over dramatic... if it was "probably" fatal, there'd be waaay fewer e46 m3 owners out there.
Driver mod > blaming the system.
For drifting, however, I can see where you wouldn't want ABS to intervene. Let us know what you find, OP
Discussing Delete ABS in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
