Old Tue, Apr-17-2018, 04:31:02 AM   #1
03FLBimmerm3
Reputation: 0 03FLBimmerm3 is on a distinguished road
Default Idle Hunting, SES light w/ Misfire codes..but car runs fine with SES on
So, after a nice refresh on M, I started encountering a consistent idle hunting that would sometimes stall the car after starting her in the morning. It would hunt for about 15 secs then stabilize. While driving and stopping at a light, however, the car would almost stall when in neutral...even worse if I had the A/C on. It would then cycle and the car would fire up and run as normal.
While driving, the SES light popped up. I got home and read the codes with ISTA:
AE: Fuel-System diagnosis, cyl. 1-3
AF: Fuel-System diagnosis, cyl. 4-6
CE: Misfiring, cyl 2 without cylinder cutout
CF: Misfiring, cyl 3 without cylinder cutout
D0: Misfiring, cyl 4 without cylinder cutout
D1: Misfiring, cyl 5 without cylinder cutout
D5 : Misfiring, several cylinders without cylinder cutout
My air/fuel ratios must be all jacked up...
Now the interesting part is the car fires up with no idle hunt and drives great with the SES light on...when I clear the codes, old problems come back and SES returns with similar codes after a good amount of driving.
I cleaned the ICV/TB/MAF sensor, replaced fuel filter, o2 sensors are all new..inspected for leaks and couldn't find any. I've reset adaptations and the car seemed to run good in the short term then I feel like the long term readings kicked back in..
Any ideas what could be causing these codes? I've read that putting the o2 sensors in the wrong place could cause this..I recently had new headers (NO CATS) installed on the car so I'm thinking maybe this? I'm going to get a new custom dyno tune soon as my current tune is probably really outdated..not sure the tune will fix this issue or not..no idea
I've attached some pics for reference. I ran my o2 sensor readings while driving around and they were moving between .1 and .9 so I think that means there working properly..I also took a look at the RU measurement screen and it said uneven running..? No idea what this means
Any ideas/feedback?
Jump to top 03FLBimmerm3 is offline   Reply With Quote
Old Tue, Apr-17-2018, 04:48:10 AM   #2
Drewster
Drewster's Avatar
Default Re: Idle Hunting, SES light w/ Misfire codes..but car runs fine with SES on
Incorrect O2 location... already answered your own question
Old Tue, Apr-17-2018, 05:08:08 AM   #3
mrgizmo04
mrgizmo04's Avatar
A lot of O2-related issues lately on the forum. Everyone must be getting the cars out of hybernation with last minute tune-ups.
O2 wires and connectors, even though they might be marked under the beauty cover with permanent markers or whiteout or whatever, could be marked incorrectly, and in a lot of cases are marked incorrectly from prior time they were changed. Unless changing one sensor at a time and plugging everything in where it came from, easy to mess up.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Apr-17-2018, 05:45:27 AM   #4
03FLBimmerm3
So the codes for sure point to incorrect o2 sensor positions? If so, my day will be made.. I will remove each one, read the location and make sure they are in the right spot
Old Tue, Apr-17-2018, 04:34:10 PM   #5
03FLBimmerm3
Here's my dilemma, I have CPI Stepped headers..the o2 sensors slots are literally right next to each other on each bank..would this really make a difference? I'm going to throw my stock intake back on with a different MAF for kicks n giggles.
Old Tue, Apr-17-2018, 04:37:33 PM   #6
Drewster
Drewster's Avatar
We're talking about O2's on the wrong bank.....
Old Wed, Apr-18-2018, 04:14:56 AM   #7
03FLBimmerm3
Ok, so I tested all my sensors, pulled them out to see what bank/sensor they were reading. I then examined where they were on my headers. Bank 1 sensor 1/2 are in the correct place. However, for Bank 2, sensor 1/2 need to be flipped. I can't get to them underneath the car as my header is the way. Would this be causing the issue? The bank 2 sensor 1/2 bungs are literally right next to each other...
Old Thu, Apr-19-2018, 06:08:50 PM   #8
03FLBimmerm3
Bump..so I swapped the sensors on Bank 2 so everything is in the correct position. Reset my adaptations and idle hunt is gone along with no SES light...then after amost 2 days of drive, the SES light came back on with these two codes..no idle hunting anymore
I took a look at my STFT / LTFT:
STFT 1: -.20
STFT 2: -.21
LTFT 1: 1.16
LTFT 2: 1.16
EDIT: After clearing the SES, putting my stock intake back in and about 5 days of driving... my fuel trims have adapted and the SES hasn't come back on..
STFT 1: -.02
STFT 2: -.02
LTFT 1: 1.04
LTFT 2: 1.03
Discussing Idle Hunting, SES light w/ Misfire codes..but car runs fine with SES on in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
