Old Tue, Jan-07-2020, 04:30:27 AM   #1
nextelbuddy1
nextelbuddy1's Avatar
Default cluster temperature range edit/change
im trying to figure out the offset location for the temperature range in the IKE/Cluster eeprom.
installing an e46 m3 cluster into a non M ZHP and getting annoyed at the temp gauge showing the needle past the middle.
if it helps, the cluster im working with is a 23H coding index.
tried following this initially
https://forum.e46fanatics.com/showthread.php?t=1013600
but quickly realized the offsets are different in the M3 BIN files bummer.
2003 ZHP 332i | S54 6 Speed | M3 Conversion
2002 ZHp Touring | M54 6 Speed
Old Tue, Jan-07-2020, 05:33:23 AM   #2
Default Re: cluster temperature range edit/change
Should be the same offsets as the CI07/8 clusters on the non-M
Old Tue, Jan-07-2020, 03:00:35 PM   #3
nextelbuddy1
ok yes you were right, on th 23H cluster it was the same. the other day i was working with a 21H and i swear every time i did a goto on 34D or 340, it said not found.
thanks for the confirmation
Discussing cluster temperature range edit/change in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
