Old Thu, Jan-02-2020, 10:36:07 PM   #1
ken o
ken o's Avatar
Reputation: 0 ken o is on a distinguished road
Default Back to stock
How can I return my DME to stock?
The numbers on the case are:
VIN
7833910
7833892
7834450
Thanks
2011 e92 M3 - Daily Driver, FS
2003 e46 M3 - TT3, XP
Jump to top ken o is offline   Reply With Quote
Old Thu, Jan-02-2020, 11:06:43 PM   #2
R3Z3N
E30 S54
R3Z3N's Avatar
Reputation: 0 R3Z3N has disabled reputation
Default Re: Back to stock
Everything here will help you figure out which OS "version" and "tune" (IE Partial bin) you are running, such that you can download the partial "tune" to flash back to stock. However as always, make a backup first.
https://github.com/saildot4k/MSS54-XDFs
Check out the Wiki here as well.
Jump to top R3Z3N is offline   Reply With Quote
Old Fri, Jan-03-2020, 04:08:32 AM   #3
eacmen
VIN
7833910
7833892
7834450
Thanks
Need to do a pull with BMW flash first and post your partial bin.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Fri, Jan-03-2020, 05:36:53 AM   #4
Or really just use WinKFP to update your module. It'll be back to stock after that (assuming you didn't do stuff like wipe out your AIF)
Old Fri, Jan-03-2020, 02:50:54 PM   #5
ken o
ken o's Avatar
The current tune is encrypted. Would this impact the restore? I have two DMEs. I would like one to be stock with EWS off, air pump, alpha-n, etc. I need the car to make less power for a race class.
Old Fri, Jan-03-2020, 05:26:01 PM   #6
The file you got from your tuner might be encrypted, but what's on the DME itself will be the decrypted. You should be able to read it out with the various free software out there.
Discussing Back to stock in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
