Old Wed, Dec-18-2019, 04:29:59 AM   #1
eacmen
Default Wonky SMG Rev Match Parameters
We recently acquired a new vehicle and it came with a tune on it. Supposedly this tune included DME parameters to improve the SMG performance as well as tuning the SMG unit itself.
I decided to dig into the tune to see exactly what they had changed and what I found seems rather odd. Either my XDF is totally out of whack or the DME looks at this table and ignores it because the values make no sense.
In my XDF the table is called KF_SMG_N_ZIEL_OFF_S, I believe it is better known as "SMG_II_TARGET_ENGINE_SPEED_OFFSET_SPORT" from this thread(http://www.m3forum.net/m3forum/showthread.php?t=457302).
Please see attached screenshot for the KOMFORT and SPORT tables. The KOMFORT table looks totally normal (copied from CSL parameters), but the SPORT table does not look normal.
Opinions?
XDF came from here: https://github.com/saildot4k/MSS54-X...4_Complete.xdf
partial bin can be found here: https://drive.google.com/file/d/1PYM...ew?usp=sharing
File Type: png Screen Shot 2019-12-17 at 9.18.44 PM.png (66.0 KB, 30 views)
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Wed, Dec-18-2019, 04:56:30 AM   #2
Default Re: Wonky SMG Rev Match Parameters
Seems like the 2501 xdf has the formula for the komfort map set to 100-((x/128)*100), while the sport map formula is set to x/128*100. I don't know which formula is correct / preferable. My 2701 xdf (which has the same layout as 2501) has both formulas set to x/128*100. Likewise with my CSL xdf. When comparing on that basis, those maps are similar to what is in the real CSL (though the sport map is different)
Old Wed, Dec-18-2019, 05:00:38 AM   #3
eacmen
Thanks terra not sure how i missed that. Appreciate you looking at it.
Old Wed, Dec-18-2019, 05:57:40 AM   #4
R3Z3N
E30 S54
R3Z3N's Avatar
Reputation: 0 R3Z3N has disabled reputation
As are there are known inconsistencies, if you are willing to correct the XDF mistakes you find, it would be awesome to correct the ones on github as well, and that would mean checking all the XDFs in this case to make sure the conversions are the same. EACMEN, you have permissions on that github to correct/change things. It might be nice to add to the wiki as well when you find things....
Jump to top R3Z3N is offline   Reply With Quote
Old Wed, Dec-18-2019, 06:18:35 AM   #5
Looks like the A2L uses the formula x/128 * 100. Brian (SliM3) seems to have preferred the 100 - x/128*100 form. Honestly I'm not even 100% sure what that map does, but my gut tells me the A2L definitions should be used whenever possible.
Old Wed, Dec-18-2019, 08:46:51 AM   #6
R3Z3N
E30 S54
R3Z3N's Avatar
^I do agree, A2L values should be used.
Old Wed, Dec-18-2019, 03:17:16 PM   #7
eacmen
Yup! that was my plan. Iíll check the others as well.
Old Wed, Dec-18-2019, 03:41:21 PM   #8
SliM3
SliM3's Avatar
Guys, I disclosed earlier when I posted my xdf that a lot of the formulas are modified/converted so I could view & interpret data with values that I'm used to seeing (i.e. Nm to ft-lbs., radians/sec to ft/sec, kmh to mph, etc.).
If you choose to reference my xdf you should or should've been aware of this & quite frankly the manager of the repository needs to add a disclaimer since I'm not actively managing that version of the xdf anymore.
Old Wed, Dec-18-2019, 04:30:59 PM   #9
These are tap's XDFs.
Old Wed, Dec-18-2019, 07:43:48 PM   #10
eacmen
2501 was the only XDF with the bad formula in it. There is a pending PR in the github project to fix it.
Discussing Wonky SMG Rev Match Parameters in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
