Old Mon, Dec-16-2019, 11:32:27 PM   #1
Nihilation
Nihilation's Avatar
Reputation: 0 Nihilation is on a distinguished road
Default Plug-N-Play injectors for 100% e85?
Rather than get the injectors cleaned and still be limited to an e85 blend, I'd rather replace the injectors to support 100% e85, naturally aspirated.
Is there a recommended drop-in injector? I understand I'd still need to have a custom time for the bigger squirters.
Thanks. Sorry if this had been covered previously!
Sent from my Pixel 2 XL using Tapatalk
2003 M3 w SMG
- B&B Triflo Section 3
- Turner Motorsport Underdrive Pulleys
- KW V1 Coilovers
- Apex Arc 8 18x9 ET30
Jump to top Nihilation is offline   Reply With Quote
Old Mon, Dec-16-2019, 11:44:05 PM   #2
SliM3
SliM3's Avatar
Default Re: Plug-N-Play injectors for 100% e85?
Bosch EV14 42lb 440cc work perfectly. Just the right amount of additional fuel on stock maps. Maybe a tad rich in some areas but it counts a lot more when you start eclipsing 8300 rpm.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Mon, Dec-16-2019, 11:45:20 PM   #3
Nihilation
Nihilation's Avatar
As in I could install thesr injectors without needing an immediate retune?
2003 M3 w SMG
- KW V1 Coilovers
Old Tue, Dec-17-2019, 12:11:15 AM   #4
jared212
Reputation: 0 jared212 is on a distinguished road
No, you would spend a ton for an oversize all stainless injector and tune. E85 is hard on rubber fuel lines and o-rings for sure. For stock injectors and fuel pumps on e85 it is no problem.
'04 SGM/Blk|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system walbro 450 e85|RMS headers|Magnaflow custom 2.5" sec1|Besian|Redish|ZCP springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishi OCC|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Old Tue, Dec-17-2019, 08:29:09 PM   #5
Nihilation
Nihilation's Avatar
Five0 Motorsport injectors wouldn't work?
https://www.fiveomotorsport.com/028u...0-028u550-bmw/
Claims:
Flow-matched, custom-manufactured fuel injector
This Fiveo injector set fits the OEM fuel rail and intake for the S54 E46 3.2L
All Viton o-rings/seals Included for installation
EASY TUNING: Minimum pulse width: 1.5 ms
Complete dead-tme (latency) table with each set.
4-hole & Single-hole disc fuel nozzles
Does not require electrical connectors adapters
2003 M3 w SMG
- KW V1 Coilovers
Old Wed, Dec-18-2019, 12:27:55 AM   #6
SliM3
SliM3's Avatar
Yes, you can get by with the stock tune but would be better in the long run if you at least get ignition timing advanced. If it's really really cold out, you may have delayed start with the factory starting pulse width.
I run 26° at idle and +3° for the base ignition map. Full load will be dependent on cams + final afr.
Old Thu, Jan-16-2020, 04:44:45 PM   #7
Deutsch
Reputation: 0 Deutsch is on a distinguished road
Hi Slim, first off, thank you for sharing all that you have with the S54 community, I've been super impressed by all of your projects!
I was hoping you could answer a few quick questions about using the 440cc injectors on E85 with the stock map? For those reading along, this is NOT a flex-fuel solution! It will only work with something near an E85 blend.
Ok, on to the questions. What Bosch EV14 injector p/n were you using? I'm assuming that it is still at the stock fuel pressure, due to the size difference between 440cc and stock, correct?
Assuming that the stock fuel maps are relatively close across the board, did you happen to experiment with cranking and after-start enrichment at colder temperatures? If so, do you recall what maps those are on an 54HP ECU?
Lastly, knowing what you know now, would you choose the 440cc or go larger and simply adjust the main fuel scalar?
Cheers,
-Doug
Jump to top Deutsch is offline   Reply With Quote
Old Tue, Jan-28-2020, 04:43:19 PM   #8
Chanman1029
Chanman1029's Avatar
Reputation: 0 Chanman1029 is on a distinguished road
I’ve got a set of bosch injectors that are plug and play with our harness and fuel rail. They’re 627cc injectors that were made for the GT2RS. Only thing you’ll need is to get them rescaled with a tune.
Jump to top Chanman1029 is offline   Reply With Quote
Old Fri, Jan-31-2020, 02:52:33 AM   #9
Andrebxp
Reputation: 0 Andrebxp is on a distinguished road
Bumping this thread, would a Bosch EV1 42lb 440cc injector be a viable substitute?
They're quite a bit cheaper and the benefits of the EV14s don't seem to really matter at this size, from what I can tell...
Thanks for sharing though since I was wondering the same thing as op.
Jump to top Andrebxp is offline   Reply With Quote
Discussing Plug-N-Play injectors for 100% e85? in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
