Old Wed, Nov-20-2019, 06:09:53 PM   #11
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Coding out SMG module
Originally Posted by wtbe46m3 View Post
Thank you guys. Using this won't wipe the Kassel tune off though? That's my biggest fear right now.
Pray it does... it might save your motor from him. (Check your minimum timing advance values)
S54 E36 BUILD
Old Wed, Nov-20-2019, 08:09:01 PM   #12
eacmen
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Fri, Dec-06-2019, 05:12:36 PM   #13
zarboz
Reputation: 0 zarboz is on a distinguished road
I have seen some interesting stuff from that shop
Jump to top zarboz is offline   Reply With Quote
Old Fri, Dec-06-2019, 06:01:20 PM   #14
rjskalet
Reputation: 0 rjskalet is on a distinguished road
Shadeeeee hahaha
if you know how to use tuner pro itís pretty easy to copy the tune over to a manual variant using the compare tool. Just have to understand where some of the differences are related to smg and manual. FYI
Jump to top rjskalet is offline   Reply With Quote
Old Fri, Dec-06-2019, 06:24:16 PM   #15
zarboz
@RJskalet I got in a fight with that guy cuz he broke someones cruise control on their 540 and wouldnt fix it... i was mind boggled there are many other vendors that are WAY more supportive
The only experience i have with manual swapping stuff is Bosch Me7.2 in the 540i/740i. This particular car toggles the starter relay differently in automatic vs manual cars and I was doing extensive research to apply 1 universal map binary to multiple models with some config switches
if you feel like poking over my change list in my other thread that would be cool.
I am curious if you can take an SMG binary and flip those 2x byte sets from SMG>Manual and run the car on a manual transmission without DTC for EGS disconnected etc
If that is the case when doing a SMG>Manual why dont you pull the partial read and flip the 2x identity bytes for SMG vs Manual flash back?
Discussing Coding out SMG module in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
