Old Fri, Feb-15-2019, 02:07:25 AM   #41
eacmen
Default Re: XDFproject BDMblock remake??
Just got my KL25Z in the mail. Hopefully I can figure out how to program it this weekend!
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Fri, Feb-15-2019, 10:39:04 PM   #42
eacmen
Status update. Code is now building and running on the KL25Z. I can interact with the menu over USB. Once I get the PCB from op and will be able to start testing BDM functionality (aka the hard part). I have a bench flashing setup and a spare MSS54HP to play with.
Old Sat, Feb-16-2019, 12:20:28 AM   #43
NZ_M3
Reputation: 0 NZ_M3 will become famous soon enough
Awesome!!!!! Shouldn’t be far away that board!!
Jump to top NZ_M3 is offline   Reply With Quote
Old Sat, Feb-16-2019, 02:59:42 AM   #44
rjskalet
Reputation: 0 rjskalet is on a distinguished road
So the question is if you guys come out with some super sweet software is it something that I can flash to my board from tap?
Jump to top rjskalet is offline   Reply With Quote
Old Sat, Feb-16-2019, 04:42:24 AM   #45
NZ_M3
I don’t see why not the hardware is the same
Old Sat, Feb-16-2019, 05:35:17 AM   #46
eacmen
We are using the same board as tap. Should be as easy as swapping the bin file on the MBED volume.
Old Sat, Feb-16-2019, 12:56:33 PM   #47
rjskalet
Awesome that’s what I like to hear. If you guys need any help testing or anything with a bdm device let me know since I currently am using Taps for my bench
Old Sun, Feb-17-2019, 08:07:00 PM   #48
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
If software is being re-done, I would really say theres the opportunity to do something more nifty than TAP did...
Make the board-software simpler coded serial-port command/response app, instead of a console-mode text-menu app.
Then write a simple windoze app that talks to it via the port with friendly buttons and interface.
No more "here's how you fire up putty and use the BDM via a console window" deal.
Basically you'd put the whole menu-ing interface on the client side, and then the board only needs to monitor the port for commands and trigger functions based on the command inputs. The whole comm protocol should't be complicated to work out.
Could even do a Mac port of the front-end if you wanted.
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Sun, Feb-17-2019, 08:57:07 PM   #49
eacmen
That's a good idea. I don't write GUI apps but willing to collaborate with someone who can!
Might be a better idea to port something like this to a raspberry pi and slap a web interface on it. Unless there are MBED web interfaces that already exist.
Old Mon, Feb-18-2019, 05:14:17 AM   #50
Yeah that would be ideal IMO. Have this interface just deal with the low level BDM setup, timings, etc. Then send your read, erase, write commands via serial. And ideally skip the SD card altogether by just reading/writing whatever amount fits in RAM at a time.
But that would also require us to actually read and understand the bdm protocol
An off-topic thought I had was whether or not it would be possible to almost entirely eliminate the necessity of a BDM interface altogether. As of right now we can do almost everything over OBDII - main thing we cannot do is erase the boot sector (and therefore the ISN). But I do wonder if it would be feasible to write a program that erases the boot sector and writes a new one. Obviously would be dangerous and a BDM would be nice to have for those inevitable screwups. But for your run of the mill virginize and CSL conversion, it would be nice to avoid opening these things up.
Discussing XDFproject BDMblock remake?? in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
