Old Sat, Dec-14-2013, 06:38:09 PM   #11
wertyu78
Reputation: 0 wertyu78 is on a distinguished road
Default Re: DTC (OBD Error Code) Deletion/Removal Strategy
Originally Posted by p0lar View Post
Let's go back to the basics. Don't worry about the offset 0x2 for now.
1) What is the year/make/model of your car?
2) What is the size of the file that you pulled? (BMWFlash? Galletto? Other?)
3) What is the 16 byte string located at either 0x7FB8 or 0xBFB8?
Answer those three questions and we'll get you rolling.
Okay!
1.This is a 2001 E46 M3.
2. I have a 32kb and a 512kb file. One partial and one full. Via BMW flash with a Galletto cable
3. How do I navigate to 0x7FB8 or 0xBFB8?
Thanks!
Jump to top wertyu78 is offline   Reply With Quote
Old Sat, Dec-14-2013, 06:44:26 PM   #12
p0lar
Naturally Agitated
p0lar's Avatar
Originally Posted by wertyu78 View Post
Okay!
Good.
Interesting method, but whatever works!
Herein lies the problem, I knew we'd get to the bottom of it.
Since you have a MSS54, you'll want to navigate to 0x7FB8, which is the 32696th byte in the file, very close to the end. You should see a bunch of gibberish on one side of your window (depending on the hex editor) and the representative ASCII on the right side (again, depending on the editor).
Since you're not using the same editor I am likely to be using, you'll likely want to familiarize yourself with how to navigate properly before jumping into a task like this. At the very least, do pass your binary past one of us here to sanitize if you make changes and want to push them back into your DME!
Examine my screen capture below of a MSS54 DME binary...
Old Sat, Dec-14-2013, 06:47:10 PM   #13
wertyu78
Good.
Excellent! Thank you for your help thus far. Do you have any recommendations on what hex editor I should use on a Windows machine?
Old Sat, Dec-14-2013, 06:53:54 PM   #14
p0lar
Naturally Agitated
p0lar's Avatar
. Sorry I can't be of more help, but I promise you probably wouldn't want to use the extremely rudimentary software I personally prefer!
Also, I do {almost} everything on OS X, so I can REALLY guarantee you wouldn't want my $0.02 for anything Windows-related.
Old Sat, Dec-14-2013, 07:19:28 PM   #15
wertyu78
I see. Well thank you for your help! I'll mess about with it further today. Hopefully I can make some progress. I just want to do away with the SES due to cat-less headers and SAP delete! it's very annoying!
Old Sat, Dec-14-2013, 07:27:28 PM   #16
wertyu78
I've lost the link, but isn't there a web page/utility in which I cannot upload my .bin file to enable shift lights (6mt) and calculate checksums?
EDIT: I've found it. TerraTool 0.5b
Old Sun, Jan-05-2014, 04:54:01 PM   #17
Acafik
Being3
Acafik's Avatar
Reputation: 0 Acafik is on a distinguished road
Default DTC (OBD Error Code) Deletion/Removal Strategy
Question excuse my ignorance.
Can I disable any code I wish or r there negative ramifications?
For example I would like to disable all of these below:
10: Crankshaft sensor
19: Ignition coil, cyl#1
17: Ignition coil, cyl#2
18: Ignition coil, Cyl#3
34: Ignition coil, cyl#5
33: Ignition coil, cyl#6
32: Ignition coil, cyl#4
29: Mass air flow sensor
15: Exhaust camshaft VANOS retard Valve
16: Exhaust camshaft VANOS advance valve
48: Intake camshaft VANOS retard valve
43: Intake camshaft VANOS advance valve
B8: Intake camshaft VANOS position control
B9: Exhaust camshaft VANOS position control
AE: Air-fuel adaptation cyl#1-4
AF: Air-fuel adaptation cyl#5-8
4F: Exhaust gas temperature sensor
89: Jet stream pump
4D: Intake air temperature sensor
The reason I want to do this is I have a piggyback CPU that handles all fuelling timing Vanos etc. so my DME is throwing codes. The car runs fine but I would like to disable theses codes so that the dash light shuts off as well as if any other code is thrown the dash light will turn on and as such be now useful should an error/ fault outside these known DTCs take place.
Jump to top Acafik is offline   Reply With Quote
Old Sun, Jan-05-2014, 06:31:49 PM   #18
Acafik
Being3
Acafik's Avatar
Another question from my ignorance.
Since I have a piggyback EMS and it uses its own 02 sensor I would like to remove the stock 02 sensors altogether. Currently I have them pugged in but not in exhaust stream. This is a turbo car and runs fine. I just would like to get rid of them and the codes. So I searched and found theses DTCs associated with 02 sensors. Anyone think I would have an issue of I disabled these and removed the four 02 sensors. Or would the car got to limp mode etc...
37 25 P0135 Oxygen sensor heater before cat., cyl. 1-3
38 26 P0155 Oxygen sensor heater before cat., cyl. 4-6
39 27 P0141 Oxygen sensor heater after cat., cyl. 1-3
40 28 P0161 Oxygen sensor heater after cat., cyl. 4-6
87 57 P0140 Signal, oxygen sensor after cat., cyl. 1-3
88 58 P0160 Signal, oxygen sensor after cat., cyl. 4-6
92 5C P0139 Oxygen sensor after cat., cyl. 1-3: voltage monitoring
93 5D P0159 Oxygen sensor after cat., cyl. 4-6: voltage monitoring
129 81 Cat. protection function limp mode
144 90 Function, oxygen sensor control, cyl. 1-3
145 91 Function, oxygen sensor control, cyl. 4-6
Old Sun, Jan-05-2014, 07:15:08 PM   #19
Tchleung
Reputation: 0 Tchleung is on a distinguished road
If you physically keep the sensors plugged in, they won't throw 3/4 of the codes you are throwing.
What Piggyback EMS are you on? ProEFI?
Follow me on Instagram @tommtomm84
09 X54.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
Now at 11 PSI...
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Old Sun, Jan-05-2014, 07:41:57 PM   #20
Acafik
Being3
Acafik's Avatar
I'm running AEM ems from Hpf .... I'm not throwing the codes because I still have them plugged in... I would like to unplug them to cleanup my wiring and then delete the associated DTCs... Would that work?
Discussing DTC (OBD Error Code) Deletion/Removal Strategy in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
