Old Mon, Oct-14-2013, 03:49:24 PM   #41
SliM3
SliM3's Avatar
Default Re: CSL SMG Engine Parameters (DME)
AWESOME.. Glad you all are enjoying the mod.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Mon, Oct-14-2013, 04:33:39 PM   #42
x Spades x
Reputation: 0 x Spades x is on a distinguished road
Originally Posted by M5TRI View Post
Here is a short clip. Thank you Brain.
http://youtu.be/w2UWnezz6u8
Is this with your foot OFF of the throttle? If not, can you make a short video of the downshift WHILE you are braking?
Jump to top x Spades x is offline   Reply With Quote
Old Wed, Oct-16-2013, 06:38:50 AM   #43
LSB FTW
Fear is exciting for me
LSB FTW's Avatar
Reputation: 0 LSB FTW is on a distinguished road
My foot is on the throttle. When i downshift while braking it rev matches perfectly and its quick. I will try to get a vid of this.
I have been driving my M3 with these new parameters, its brutal fast at the S5 level.
Its a huge improvement and it works perfect with the SMG CSL flash. This so worth it!
Jump to top LSB FTW is offline   Reply With Quote
Old Wed, Oct-16-2013, 11:43:04 PM   #44
x Spades x
I'm excited to see vid! Thanks for doing this, in advance. I get my car back in 2 days, so I'm eager! :-)
Old Thu, Oct-17-2013, 07:12:33 AM   #45
certify
Reputation: 0 certify is on a distinguished road
Malaysia
Do I need to reset the SMG adaptation? I do however heard horror stories after SMG adaptation was done.
Jump to top certify is offline   Reply With Quote
Old Thu, Oct-17-2013, 07:22:19 AM   #46
m3vertsmg2
Formerly new//m3fan
Reputation: 0 m3vertsmg2 is on a distinguished road
It needs to be done in the proper order... It is also a requirement after module replacement or module updates per TIS.
*F-BOMBS IN SIGS*
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things
Jump to top m3vertsmg2 is offline   Reply With Quote
Old Thu, Oct-17-2013, 07:41:46 AM   #47
certify
Malaysia
Using DIS.. http://www.m3forum.net/m3forum/showthread.php?t=401829
ok?
Old Thu, Oct-17-2013, 02:18:51 PM   #48
Donkey1
Reputation: 0 Donkey1 is on a distinguished road
Germany
You can do the adaptions with INPA or DIS but keep in mind that you need an interface which regonizes the ignition otherwise it won't work. The cheap interfaces don't have this feature, they just simulate ignition and battery voltage.
About rev matching:
The curve KL_SMG_N_ZIEL_OFF_AH stores three rpm values for a specific deceleration rate. Are these the rpm which will be added? For example for deceleration of 2m/s the rpm value is 1000. Does it mean that in case of a downshift I add 1000 rpm to the current rpm value to match the speed of the lower gear?
In this case a higher rpm value would result in more aggressive rev matching, but we've got to make sure that not too much rpm are added otherwise it will be jerky.
Jump to top Donkey1 is offline   Reply With Quote
Old Thu, Oct-17-2013, 04:20:18 PM   #49
m3vertsmg2
Formerly new//m3fan
Yes,
Characteristic clutch valve, clutch curve, Full trans adapt (running through gears) Clutch take up point, and longitudinal sensor in that order IIRC.
*F-BOMBS IN SIGS*
Old Mon, Oct-21-2013, 01:43:23 PM   #50
SliM3
SliM3's Avatar
Hey all, I did a file for someone that is running a 3.91 rear diff and I'm looking for feedback, but I can't remember who it was.
I'm working on improving the rev-match for guys with 3.91/4.10 rears and have adjusted the target RPM's on my car, but I'm running the stock diff. The idea is to better match the rpm targets to the increased engine overrun (braking) speed induced by going to lower ratio gears.
If anything, could someone chime in on just how much of an engine speed increase there is, compared to the stock diff?
-Benjamin Franklin
Discussing CSL SMG Engine Parameters (DME) in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
