Old Fri, Apr-24-2015, 05:57:26 PM   #51
ccurtis01
Reputation: 0 ccurtis01 is on a distinguished road
Default Re: DIY: Flickering headlights, taillights, ground issue FIXED
Just updating this thread. It was indeed the bulbs themselves. I replaced 1 at a time and noticed it corrected the issue on that side. The seemingly 'high beam' issue was just that when the light flickered, when it fired back up there was a momentary burst of light that appeared to be "flashing" the high beams.
Jump to top ccurtis01 is offline   Reply With Quote
Old Wed, Apr-29-2015, 02:47:10 AM   #52
djcim
Reputation: 0 djcim is on a distinguished road
I'm having the same issue of the passenger light going out then back on and so on. I have single xenons, but I'm not sure where to start, replace bulbs? Ballast? Ignitor? What seems to be the consensus? Thanks
Jump to top djcim is offline   Reply With Quote
Old Thu, Aug-20-2015, 12:20:16 AM   #53
PWRXM
PWRXM
PWRXM's Avatar
Reputation: 0 PWRXM is on a distinguished road
2004.5 111,111 km (69,000 mi) second set of CBIs, beautiful colour and lumens. Over the past few months of summer, I have had intermittent LH Xenon light out events. Swapped bulbs issue remained on the LH side. Purchased a new ballast from ECS tuning for US$250 and worked for the first week, then the dreaded flicker and light out indication. Bulbs were less than a year old. So tried "terraphantm's" bulb socket prong adjustment technique and discovered some light burn marks from arcing from either one of the outside three prongs or the centres on the inside socket ring. Small flat screwdriver and tweaked the centres inward and the outers inward. Needed to pry back the centres a little, couldn't twist the socket back on. Did this 30 minutes ago, so I will check back in a week to report back on the performance. This looks like a very plausible solution and hopefully eliminate the arcing.
Jump to top PWRXM is offline   Reply With Quote
Old Tue, Aug-25-2015, 12:01:29 AM   #54
PWRXM
PWRXM
PWRXM's Avatar
Light flicker returned after two days! Will continue the journey to solving this one.
Old Tue, Aug-25-2015, 08:25:14 PM   #55
Pnick
Pnick's Avatar
Swap the ignitors left to right. Requires you to disassemble the headlight assembly though or replace it outright.
Old Wed, Sep-16-2015, 03:28:37 PM   #56
ccurtis01
Bulbs are the easiest and cheapest, I would start there. I bought the ebay ones and have had them for 6 months, still going strong!!
Old Wed, Nov-22-2017, 08:27:22 PM   #57
Kwakjoe
Kwakjoe's Avatar
Sorry to gravedig, but did anyone ever figure this issue out? It's happening with my passenger side headlight. It'll only stay on for maybe 5-15 minutes and completely turn off until I turn it off then back on and then it'll stay on for maybe 1-3 minutes before turning off again. I wanted to see if anyone figured it out before I start ordering stuff.
Old Mon, Mar-12-2018, 09:11:51 PM   #58
Alex Sol
Alex Sol's Avatar
Reputation: 0 Alex Sol is on a distinguished road
wow, a little quiet on this thread for last 4 months.. and don't want to start a new one on the same subject..
i think OP needs to change the title to fixed ground issue, then issues came back.. then sold the car and problem solved... kidding here of course.
i read through this post and it seems there are 5 main issues on the flickering or the turning off and on (which mimics high beams and annoys people in front of you)...
bulbs - replaced
ignitor - check for contact and clean up the area due to possible corrosion and just plain harsh environment
ballast - can these be checked ie: resistance check or some way to put power to them and test?
ground - look in rear tail light section but how do you know it's the correct one? fire up car, disconnect ground and the light(s) will turn off.
thanks for clarifying before i do some digging.. or worse... spending money needlessly.
1991 Guards Red Porsche 964 C2
2009 335d
2003 m3
Jump to top Alex Sol is offline   Reply With Quote
Discussing DIY: Flickering headlights, taillights, ground issue FIXED in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
