Old Thu, Oct-12-2017, 03:41:52 PM   #301
Default Re: Obioban's 332iT Daily
Originally Posted by JaredMV View Post
Hey Ian, how's your daily holding up?
Awesome
Just rolled over 182,000 miles yesterday. Did an inspection 2 (filters/fluids/plugs/valve adjustment) at 180,000 miles.
I've actually done a couple projects I haven't documented on here yet-- roof rack delete and black headliner/pillars.
I also have a big winter for it planned:
-head gasket (not leaking, but at some it'll be needed and I'm already removing the headers, which is half the job done)
-euro headers
-euro catted section 1
-head decked, valve guides and seals replaced (again no issue, but with the head off it seems silly not to at what will be 19X,XXX miles on it)
-entire cooling system
-egt relocated
-euro tune
-new pulleys/belts/tensioners
-clean the idle control valve and starter terminals (no issues there currently, but I'm a believer in doing that while the intake manifold is off
-I may replace the PITA TPS while I'm in there, and throw the existing good one in the spare tire well for road side repairs
-and at some point I still have upgraded projectors I need to install in it and new headlight lenses. I'll probably do that while the head is away, since the car will be offline either way.
It's a lot of stuff at once, but it's a lot of shared labor, so it should go pretty quickly. WhileYoureInThereitis bit me big time.
Parts are piling up in my garage
Old Thu, Oct-12-2017, 03:51:42 PM   #302
sooch
Reputation: 0 sooch is on a distinguished road
I'm very tempted to join you in the 5 series Beater category.... There's 5-6 in my area at sub 2k in decent shape. The initial price wouldn't be too bad, just worried about upkeep on some neglected cars...
Jump to top sooch is online now   Reply With Quote
Old Thu, Oct-12-2017, 03:54:24 PM   #303
I'm also working on overhauling the way the rear brakes work. Stock, the running lights are stupidly (dangerously) dim.
Sooooo, my plan is...
-put two stage bults in the inner and outer brake lights, and the fog lights. Code them all to come on dimly as running lights (tippling the running light quantity)
-standard braking will now be the inside and outside brake lights (used to be just the inside), bright, plus the 3rd brake light
-Brake force display stage 2 (hard braking) will add the rear fog lights (both left and right) at full bright
-Brake force display stage 3 (ABS braking) will keep the above, but strobe the 3rd brake light and outside brake lights
In the process I should be gaining headlight aiming control via the dial and rear fog lights on demand (for when it's foggy), as I bought a euro LCM faceplate.
Old Thu, Oct-12-2017, 03:55:28 PM   #304
I actually think I'm going to sell mine. It's just a bit too beat for me to be able to enjoy it.
... I do want another, in better shape.
Old Thu, Oct-12-2017, 03:58:00 PM   #305
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
*cough* M5 touring conversion *cough*
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
Old Thu, Oct-12-2017, 04:04:06 PM   #306
I don't think it works as well. The e39 touring has MUCH different suspension geometry than the sedan (including airbags), and is just never precise.
If I were to swap an e39 touring, I'd put a V12 in it. The e39 is a KICKASS comfortable cruiser, and the V12 would enhance that.
... but recently I've been obsessing about doing a 2002 with an F20C with iVTEC retrofit
Old Thu, Oct-12-2017, 08:44:03 PM   #307
Dave B
M3 collector
Dave B's Avatar
Italy
Whoa.
That's one of those "how have I never heard of or thought of it before" ideas that is just kind of perfect...
Then again, once you're out of M engine/suspension territory, it's hard to make the argument for an E39 touring with V12 over just an E38 750iL as a comfy cruiser.
Old Thu, Oct-12-2017, 08:49:21 PM   #308
Originally Posted by Dave B View Post
Whoa.
Yeah-- the e38 750iL is on my short list of future cars
Old Sun, Nov-19-2017, 01:59:56 AM   #309
I've done a couple of projects that I haven't gotten around to taking pictures of or posting about-- namely roof rack delete, huge brake light output upgrades, and black headliner/pillars. Hopefully I will soon.
Until then, I installed this today. Belongs to a friend of mine, but I'm "storing" it for him for a couple of weeks in the wagon. Previously I've only had Sparco seats in track cars, never a Recaro or in a street car. This thing is definitely on a higher tier.
Recaro Profi SPG XL with a Brey Krause R-9222 seat mount on a BMW e46 power slider.
Initial impressions:
-getting in and out of the car sucks
-once seated, it's remarkably better (and comfortable)
-the stock 3 point belt receiver with the pre tensioner isn't great in either of the two ways you can run it (over the seat or through the hole). One way it digs into you, the other way it's too high for good contact. If I was going to run this long term, I'd likely use a rear seat belt receiver up front to get it better positioned, though it would be a shame to lose the pretensioner in the process.
-the headrest feels too far back (likely for helmet clearance) and a bit too little padding to be safe without a helmet
-the seating position is completely wonderful. This must be what it's like to be a normal person height. I can fit an entire fist above my head, and this car has a sunroof! I also don't have the steering wheel in the highest position. Traditionally I have to recline the seat a bit to fit in the car with a helmet on-- sub optimal.
All told, gives me lots of things to consider for this winter's seat project in my M3 coupe.
Old Sun, Nov-19-2017, 05:03:37 PM   #310
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
This is really cool!
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Discussing Obioban's 332iT Daily in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
