Old Sat, Oct-12-2019, 02:52:25 AM   #31
Ajcanadian
Reputation: 0 Ajcanadian is on a distinguished road
Default Re: Advice needed for a potential purchase
Originally Posted by Nate047 View Post
Right on man, fuggin send it! For real though, make sure the tires are new and safe. Check the dates.
Hahah will do. They are old pretty sure. They are showing their age. But the cars going to get parked until I sell my 328/5 that decided to shit a clutch slave cylinder the next day I bought the M3
Sent from my ONEPLUS A6013 using Tapatalk
Jump to top Ajcanadian is offline   Reply With Quote
Old Sun, Oct-13-2019, 10:49:02 PM   #32
Ajcanadian
It was a slow day at work and like any normal teenager, I got on my phone. I was curious to find out who built my M3. So I decided to pull up Facebook and see if I could find out my car's previous owner(s). With some luck I found out who built it and got some info out of him. Here's what I found out
Powertrain
- 99 S52 engine & trans with 51k original miles (160k miles on body when swapped, OBD1 converted). Currently has 197K miles on chassis, so around 88K miles on powertrain (2010)
- M50 manifold (2010)
- Dinan performance chip (2010)
- AA (header-back) exhaust with catalytic converter removed (OBD1) (2010)
- AA light fly wheel, AA stage 3 clutch (2010)
- Dinan cold air intake system (2010)
- Electric cooling fan conversion (2010)
- Rogue Engineering short shifter kit (2010)
- Delrin shifter bushing kit - ECS Tuning (2015)
- Lemforder OE clutch slave cylinder (2013)
- Power steering reservoir and lines replacement - Turner Motorsports refresh kit (2015)
- Flex Disc / Guibo - Turner Motorsports (2015)
Cooling system
- BimmerWorld complete cooling system overhaul kit (Radiators, water pump, thermostat, hoses, etc.) (2010)
- Rally road oil cooler cap, with custom engine oil temp sensor and gauge (2012)
- Water cooled oil cooler (Currently disconnected to use the upgraded custom air-to-oil Setrab oil cooler setup in 2013) (2012)
- MMW custom Setrab Oil Cooler Setup with all AN lines and fittings (2014)
- S54 E36 M Coupe radiator - 3 Core (2014)
- Stewart Racing water pump (2014)
- 80C Thermostat from 1987 325is (2014)
Suspension
- H&R race springs (2012)
- Koni Yellow adjustable shocks (2012)
- BimmerWorld front end overhaul kit (control arm, tie rod, sway bar end links) (2012)
- BimmerWorld solid control arm bushings (2012)
- Turner Motorsports anti roll bar (front and rear) (2012)
- Dinan front strut brace (2012)
- Dinan rear strut brace (2014)
- Strut/shock mount kit - Includes upper strut bearings, upper strut reinforcements, Repair Shop (lifetime guarantee) rear shock tower mounts, all gaskets, washers, bolts, flange nuts. (2014)
- Poly-urethane transmission mounts - UUC HD (TMBLUE) (2014)
Brakes**
- Brembo (blanks) front rotors, OE size (2015)
- Hawk DTC60 front pads (2015)
- Carbotech XP8 rear pads (2014)
- Centric (blanks) front rotors, OE size (in storage) (2014)
- Carbotech XP10 front pads (in storage) (2014)
Interior & Exterior**
- Upgraded MB Quart front & rear speakers (2010)
- HID projector halo angel eye headlights with digital blaster (2010)
- Euro OEM clear lights, front and rear (2010)
- Momo steering wheel and illuminated M shifter knob (2010)
- Alcantara black suede headliner, door panel inserts, shift boot and e-brake boot (2011)
- 17 BBS Style 5 wheels, polished lips with white bolts (Direzza Z2 tires) (2012)
- Original black Vader seats (2012)
- Black Vader seats
Fluids
- Engine: Motul 8100 X-Cess 5w40 Fully Synthetic Oil (2015)
- Coolant: 50% distilled water, 50% BMW original coolant (2014)
- Transmission: Redline MT90 (2014)
- Differential: Redline 75w140 (2014)
- Power Steering: Mobil 1 ATF (2015)
- Brakes: Motul RBF600 (2015)
Needless to say, this guy took really good care of the car until he sold it. The guy I got it from just let the car sit. Here's some pictures of the car from this guy's ownership.
Old Sun, Oct-13-2019, 11:57:24 PM   #33
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Reputation: 0 GG///M3 is on a distinguished road
Albania
Looks great(Im a sucker for alpine) . Remove wheels when you can, and sell them
Jump to top GG///M3 is online now   Reply With Quote
Old Mon, Oct-14-2019, 12:38:28 AM   #34
Ajcanadian
I have a set of light weight rims that I will put on the car eventually. Cosmetic items can wait. Mechanical items are my priority
Old Sun, Oct-27-2019, 11:02:13 PM   #35
englishtom1596q
englishtom1596q's Avatar
looks like you didn't like the car too much?
https://toledo.craigslist.org/cto/d/...006564092.html
and trying to make some money off it lol
Old Sun, Oct-27-2019, 11:27:51 PM   #36
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Albania
Ha
Old Mon, Oct-28-2019, 12:30:54 AM   #37
Ajcanadian
I've got two cars right now and both my cars are for sale. The 328/5 and the m3. My thought process was to sell the 328 so that I can garage the M3 in the winter and buy a cheap winter beater. However, I've gotten 0 bites on the 328. It also goes the same for the M3.
Not that I don't like the car. I really haven't driven it at all since I'm a full time mechanical engineering student and the M3 stays at my parents house.The car has been parked until the last few days. I've done some work to it and have driven it again and have fallen in love with it all over again. Thus, I've been in a dilemma if I should just keep both cars. But from seeing my situation I'm probably going to store the M3 at my parents during winter and just keep the 328 as a winter car which I hate to do
If you had to sell your car would you sell it below market value?
Old Mon, Oct-28-2019, 03:45:51 AM   #38
englishtom1596q
Im in that situation currently and yes i would lol. A bird in the hand is worth 2 in the bush.
Old Mon, Oct-28-2019, 03:48:30 AM   #39
Ajcanadian
I understand your thought process. For me, the extra cash would help expedite the process of me building the M3 but truth be told, I love seeing both e36s parked next to each other haha.
Discussing Advice needed for a potential purchase in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
