Old Sun, Jul-17-2005, 11:07:01 PM   #1
Fly'n DuthhMan
Apex Sniper
Fly'n DuthhMan's Avatar
Reputation: 0 Fly'n DuthhMan is a jewel in the rough
Default DIY Front Bumper Removal
I took some pictures of my front bumper removal. It really isn't that hard to do. You'll need a jack and some basic hand tool and six point deep sockets.
The bumper is held on by two main bolts that need to be accessed from under the front lip. Then there are 4 smaller bolts on each side of the bumper that hold the bumper cover to the front fender liner. Additionally the bumper is support by two white plastic brackets on either side, they don't need to be unbolted, they just slide off when the cover comes off forwards away from the car.
I thought you guys might be interested, I had to remove it to mount my inlet ducts for my bimmerworld brake duct kit.
Jump to top Fly'n DuthhMan is offline   Reply With Quote
Old Sun, Jul-17-2005, 11:08:50 PM   #2
Fly'n DuthhMan
Apex Sniper
Here are some pics of the main bolt locations, and the access whole.
Note The white cone shaped plastic things are to help guide your socket and bolt during assembly/disassembly
Old Sun, Jul-17-2005, 11:09:57 PM   #3
Fly'n DuthhMan
Apex Sniper
Picture of hte inside of the bumper and mounting location
Old Sun, Jul-17-2005, 11:16:24 PM   #4
Fly'n DuthhMan
Apex Sniper
Just some misc picture of the complete project.
Old Sun, Jul-17-2005, 11:17:39 PM   #5
Dooly
Gold Member
Dooly's Avatar
Reputation: 0 Dooly has disabled reputation
South Korea
Great Writeup!
I've only seen non M e46 diy's, thanks
Jump to top Dooly is offline   Reply With Quote
Old Sun, Jul-17-2005, 11:27:04 PM   #6
M3Pipes
USAF Fighter Jet Mechanic
M3Pipes's Avatar
Reputation: 0 M3Pipes is on a distinguished road
Thanks for taking the in depth photos! I was always skeptical about removing the front bumper because of airbag reasons but I guess the sensors are behind the front structured beam.
On another note, your bumper looked a bit beaten up. What happened there? I'm not knocking your work but the install looks like it's hanging a little low on the passenger side. Am I seeing things? :nixweiss:
2004.5 Silbergrau ///M3 coupe SOLD
2012 Jeep Grand Cherokee Overland 2WD HEMI V8
Last edited by M3Pipes; Sun, Jul-17-2005 at 11:44:41 PM. Reason: Adding information
Jump to top M3Pipes is offline   Reply With Quote
Old Mon, Jul-18-2005, 12:17:13 AM   #7
Fly'n DuthhMan
Apex Sniper
No your right, that side caught on a parking block a couple times. The part of the bumper cover that attaches to that white support is a little tweaked and doesn't fit up as tight anymore. Also I hadn't reinstalled the fender liner on that side when I took the pick, which would support that a little more.
There is nothing in the bumper cover other than alum bumber, fog lights, horns, and two air temp sensors. Just lots of plastic. 22 pounds worht total btw.
Old Mon, Jul-18-2005, 07:06:44 AM   #8
bvnmspt
bvnmspt's Avatar
Reputation: 0 bvnmspt is on a distinguished road
Great write up.
Is your car an 01 because your bumper assembly looks different from mine.
I'm not sure about the 02s, but the 03s+ comes with carbon fiber bumper reinforcement. On the 03s, you don't have the bolt that goes through the bottom. They use 4 balls and sockets and all you have to do is to pop the bumper reinforcement on to the chassis.
Dream as if you'll live forever. Live as if you'll die today.
Jump to top bvnmspt is offline   Reply With Quote
Old Wed, Oct-19-2005, 11:45:51 PM   #9
m3griff
Reputation: 0 m3griff is on a distinguished road
Fly'n man (or anyone that has knowledge of this)
This a late post, but I have an 02 with the same bumper attachment that you show (BTW - thanks for the DIY). Can you elaborate on what you had to do to remove the bumper - other than the bolts? I have gotten everything loose and removed the two big Torx bolts, but the bumper is still semi-attached on the passenger side. It appears that the windshield washer reservoir is attached to the bumper. It would not come loose (I didn't pull real hard..). Any insights?
Thanks.
Jeff
2006 Z4 3.0Si
TiAg
6 spd.
Jump to top m3griff is offline   Reply With Quote
Old Wed, Oct-19-2005, 11:48:17 PM   #10
Grimm333
that one guy...
Grimm333's Avatar
Reputation: 0 Grimm333 has disabled reputation
awesome write up man!!!
22lbs of plastic
thats some weight savings there
Teh Grimmoble!!11one
Jump to top Grimm333 is offline   Reply With Quote
bumper, diy, front, removal
a little help please....01 front bumber removal diy ArtM3 E46 M3 (2001-2006) 5 Sat, Jul-14-2007 06:56:02 PM
Diy Removal Front Bumper?? ksort86 Faults, Fixes and DIY 6 Tue, Jul-18-2006 07:44:19 PM
Bumper Removal & Install - DIY icoburn E46 M3 (2001-2006) 5 Mon, May-24-2004 04:42:09 PM
Bumper Removal & Install - DIY icoburn Parts for Sale/Wanted 0 Mon, May-24-2004 06:27:29 AM
Does anyone have a DIY for front and rear bumper removal? Matt_337 E46 M3 (2001-2006) 0 Thu, Sep-25-2003 12:46:04 PM
Discussing DIY Front Bumper Removal in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
