Old Sun, Apr-24-2016, 07:29:37 PM   #181
jdev
Reputation: 0 jdev is on a distinguished road
Default Re: Front Strut Tower Pulling Away from Body?
Originally Posted by fastmonbbs View Post
I just checked mine. A hairline crack in the seam filler (driver side) but the metal is intact and no sign of the weld pulling of cracking. Passager side is good. 135xxx miles on a 2004 and I do a lot of spirited driving on backroads
Here is my passenger side. Driver's side has a smaller hairline break in the sealer.
02, always had OEM strut brace and stock suspension.
115k miles.
I'm the second owner. dealer serviced not-abused car.
Seamer sealer along the strut attachment points looks good.
Guys that have larger amounts of separation like above should definitely have a closer look at the fender well sealer and inside the fender area at the spot welds.
02 Silver/Red
Jump to top jdev is offline   Reply With Quote
Old Sun, Apr-24-2016, 10:18:37 PM   #182
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
Originally Posted by JaredMV View Post
Just looked today and I've got myself a tear and a crack.
Side note: It looks like there's a lot of pollen(?) in my engine bay. Anyone have a good way to clean it up?
Passenger side:
Driver side:
Simple green & some elbow grease and good rinse
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Sun, Apr-24-2016, 10:21:21 PM   #183
01M3Fan
01M3Fan's Avatar
Originally Posted by jdev View Post
I agree with you. I'm not making a factual claim. That is not my purpose at all. Given what I think is enough circumstantial evidence though, at this point I do think it's worthwhile to objectively investigate to confirm, dismiss, or modify the theory that the shock towers through some usage variables are subject to separation from their mounts in the upper and middle areas of attachment. My theory also is that the attachment failures aren't generally enough in most cases to notice a problem, particuarly if the car has a shock brace holding things relatively stable, combined with the fact that people dont' take fenders off for any kind of routine inspection would naturally leave us ignorant of issues behind the fender.
The picture just above is not healthy. It may not be catastrphic, but it's not "right" in my opinion. The cause for smaller issues, I don't think is old seam sealer. The passenger side has permanently relocated and broken the spot weld up top. The driver's side looks like stress, but don't see evidence of metal failure. That is the perfect car to remove the fender to examine the rest of the strut tower attachment points. Thanks for the oppotunity to answer your question here by the way. Please feel free to offer suggestions and opinions.
By the way, if you're reading, I know it's a pain, but if you would be brave enough to have a look, the community may benefit greatly from knowing if you have other metal failure behind the fender, or not.
Ok - I have separation up top & car is going on jack stands to put in front shocks so I'll take a look under fender liner & report back next weekend when I have my shocks back.
Old Thu, May-19-2016, 01:18:29 AM   #184
Yar1
Yar1's Avatar
Reputation: 0 Yar1 is on a distinguished road
I have a similar separation as JaredMV has on his driver side, passenger side is sound though. However, have we found a solution to this or a way to prevent further tearing?
I'm of the mind to use epoxy or extra seam sealer.
2004 ///M3 SMG II Coupe Silbergrau OEM+
Jump to top Yar1 is offline   Reply With Quote
Old Mon, Oct-10-2016, 01:59:29 AM   #185
the404man
the404man's Avatar
Reputation: 0 the404man is on a distinguished road
Yes mine too both sides looks that of post #182 passenger side.. any one come up with a good fix yet, and do strut tower braces seem to help any and where is a good place to find factory strut tower braces? ill tell ya iv been looking and all i can find is after market.. but im new to bmw as this is my first ever, but i am still so happy with it BIG TIME ha iv always wanted a bmw and btw its a 323i e46 5 speed
New BMW 323i E46 m52tub25
https://www.youtube.com/watch?v=QnGIgjvE8Dg
Summit Racing Turbo Muffler vs 2 Chamber Performance Muffler
https://youtube.com/watch?v=9IqeiA1VN-M
6.0 LQ4 to 5.3 LM7 FIRST START UP
https://youtube.com/watch?v=srko18Z7MAk
5.3 LM7 Deformed Main Bearings & LQ4 Removal
http://youtube.com/watch?v=KYIjOFzhydo
Coming Soon Will It Hone Series Rusted 4.8/5.3
https://youtube.com/watch?v=P348dZQGdsg
Jump to top the404man is offline   Reply With Quote
body, front, pulling, strut, tower
Discussing Front Strut Tower Pulling Away from Body? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
