Old Wed, Nov-04-2009, 02:19:37 PM   #11
to174jay
Reputation: 0 to174jay is on a distinguished road
For everyone that posted that they are having the same issue as me, are you guys hearing a creaking or squeaking noise? I ask because its probably completely different issues. Mine sounds like a really short creak, ALMOST like a 'strong tick', if that makes any sense.
Jump to top to174jay is offline   Reply With Quote
Old Wed, Nov-04-2009, 08:09:20 PM   #12
chasem3
chasem3's Avatar
Reputation: 0 chasem3 is on a distinguished road
Egypt
I have the same issue. Had my car checked many times and nobody was able to find anything wrong with it. So I just gave up. Do you live in the Northeast or somewhere that gets cold? I ask because mine creaks in the winter only when the temperature is consistently below 50 degrees.
After replacing my suspension to PSS10's, the sound got considerably less frequent. But I now have a sound from the compression of the Bilstein springs.
Jump to top chasem3 is online now   Reply With Quote
Old Wed, Nov-04-2009, 09:59:25 PM   #13
akaveli3
akaveli3's Avatar
Reputation: 0 akaveli3 is on a distinguished road
Yeah I'm the second owner. I purchased my car in Connecticut and I live in NYC! So my car was and still is in cold weather in the winter.
Jump to top akaveli3 is offline   Reply With Quote
Old Tue, Jul-19-2011, 06:25:30 AM   #14
KrnkM3
KrnkM3's Avatar
Reputation: 0 KrnkM3 is on a distinguished road
Default Re: Creaking front front suspension HELP!
I had the loud "Tick" your describing. Unfortunately my issue was bad balljoints and replacing the control arms is the cure. $300 a piece. After that issue was solved I began to hear a Squeak from the front suspension on even the smallest bumps. After being told it was without a doubt the FCAB's I ordered Polyurathane bushings from bavauto. After installing them the squeak was still there and Im still hearing the squeak. Anything else it could be other than FCABs?
-Brandon-
Jet Black 2001 6 Speed M3 on 19" Hyperblack CSL replicas
Ran 13.609@ 102.62 MPH.
Jump to top KrnkM3 is offline   Reply With Quote
Old Sun, Oct-07-2012, 03:24:48 PM   #15
AK_Topwise
Reputation: 0 AK_Topwise is on a distinguished road
Did anyone ever find a solution to this issue? My front suspension is creaking pretty bad especially with weight shift (ie entering exiting drive way one front wheel at a time)
TiAg 2005 E46 ///M3 18" VMR VB3 / Macht Schnell Stage 1 Intake Kit / Status Gruppe Tuning Headers, Section 1 & Titanium Tip Muffler / Evolve-R Tune / Koni yellows / Eibach Pro-Kit / Rogue Engineering RTAB's + RSM's / AutoSolutions 30% SSK / ICONZ CSL Style CF Front Lip (painted matte black) / ICONZ CSL Style CF Rear Diffuser / Matte black grills & gills / Matte black roundels & emblems / Tinted taillights / Smoked corners & reflectors / Tinted windows
Jump to top AK_Topwise is offline   Reply With Quote
Old Sun, Oct-07-2012, 04:11:57 PM   #16
Jako1
Jako1's Avatar
Reputation: 0 Jako1 is on a distinguished road
Sway bar bushings.
Jump to top Jako1 is offline   Reply With Quote
Old Sun, Oct-07-2012, 05:14:05 PM   #17
Hredlus
Hredlus's Avatar
Reputation: 0 Hredlus is on a distinguished road
This may be lame, but just watched show Wheeler Dealers, and they referb'd an M5 with same symptoms. The top of the strut has a rubber bushing that was trashed, the very top 'cap' that basically you see at the top of the tower. That was the issue on that... Like everything on that show, it looked like a simple fix. All you need is an Edd China tool and it's fixed in minutes for nearly no money.
Jump to top Hredlus is offline   Reply With Quote
Old Sun, Oct-07-2012, 07:16:10 PM   #18
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
Saw the same show. You never know!
2002 E46 M3 ~ SMGII
VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is offline   Reply With Quote
Old Sun, Oct-07-2012, 11:55:00 PM   #19
Rupes
2003 BMW M3
Rupes's Avatar
Reputation: 0 Rupes is on a distinguished road
I also have the same issue -03 convertable 45k. More of a squeek under acceleration or corners and mines coming from the drivers side rear wheel area. Just replaced Rtab's and rsm's but doesn't seem to matter. Could it be subframe? God, I hope not.
Jump to top Rupes is offline   Reply With Quote
creaking, front, suspension
Discussing Creaking front front suspension HELP! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
