Old Tue, Nov-03-2009, 01:11:23 PM   #1
to174jay
Reputation: 0 to174jay is on a distinguished road
Default Creaking front front suspension HELP!
Hey fellas,
Recently, my 2002 M3 has started making a creaking noise from what sounds like front wheel wells (in that area) whenever the weight shifts; hard braking, sharp turns, and even when slowing down normally when approaching a red light. I can feel a slight "tick" when my left foot is resting on the floorboard of the driverís seat whenever I hear the creak. Has anyone experience this?
I have a few basic suspension mods: Front and rear strut/sway bars and shocks and springs.
Thanks in advance,
TJ
Jump to top to174jay is offline   Reply With Quote
Old Tue, Nov-03-2009, 04:42:14 PM   #2
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
Sway bar end links? Or FCABS?
2002 E46 M3 ~ SMGII
VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is offline   Reply With Quote
Old Tue, Nov-03-2009, 05:30:20 PM   #3
to174jay
I initially thought it was the FCABS, but from the research ive done, that wouldn't make a creaking noise (more of a squeak).
I'll check the sway bar links, but im not exactly sure what they are...are they where the sway bar attaches to the strut under the hood?
Old Tue, Nov-03-2009, 06:32:16 PM   #4
AltF4
In for pics...
AltF4's Avatar
They attach from the sway bar to the top of the strut in the wheel well. Here are mine:
http://www.m3forum.net/m3forum/showthread.php?t=289026
b
2002 E46 M3 ~ SMGII
Old Tue, Nov-03-2009, 06:48:00 PM   #5
to174jay
b
Hmmm, just got done reading your thread. It appears that you didnt have any noise that you noticed associated with it? The sound that I am hearing seems to almost like a creaking door for a brief second or when hitting a bump. I'm not really car savy so honestly, couldnt make head or tails of the pics. Are the pics shown a place I can access by removing the wheels?
Thanks for your help man,
Tony
Old Tue, Nov-03-2009, 06:57:33 PM   #6
bvnmspt
bvnmspt's Avatar
Reputation: 0 bvnmspt is on a distinguished road
Originally Posted by to174jay View Post
Hey fellas,
Thanks in advance,
TJ
I'm experiencing the same issue. Do you have any deterioration in the handling of your car? Does your steering wheel vibrate at high speeds? Does your steering feel overboosted? Do you find yourself correcting your steering to keep the car going straight? Does your front end feel light? If so your FCAB is probably shot. BTW, how many miles do you have on your car? Mine has 72k on it and I just ordered new bushings. If your car is a 2002 and never had the FCAB replaced, then I would look into replacing them. The passenger FCAB is nortorious for failing since the heat from the exhaust manifold thermal cycles it.
Dream as if you'll live forever. Live as if you'll die today.
Jump to top bvnmspt is offline   Reply With Quote
Old Tue, Nov-03-2009, 07:04:46 PM   #7
to174jay
I havent had any of the symptoms you described at all. None whatsoever, which is why I thought the FCABs couldnt be the issue. My car has about 50000 miles give or take....
Please let me know if replacing the FCABs fixes your issue.
Old Tue, Nov-03-2009, 08:28:53 PM   #8
AltF4
In for pics...
AltF4's Avatar
Could it sound like metal rubbing maybe? Maybe your shocks are out?
2002 E46 M3 ~ SMGII
Old Tue, Nov-03-2009, 08:58:42 PM   #9
akaveli3
akaveli3's Avatar
Reputation: 0 akaveli3 is on a distinguished road
I have same the same issue. I have an 02 with 58k on it. I changed the front strut mounts, sway links and fcab's. Suspension feels much better but I still have the squeak and where I really feel it is on the drivers side and also feel play in the drivers side wen I hit bumps making turns. Passenger side was fine before everything was changed and after. Also changed the tie rods or the control arms and squeak was there.
Edit: After changing all that stuff in my suspension my squeaking actually turned out to be my drivers seat. If I bang against the seat I can replicate the squeaking, although it sounds as if the noise is coming from the front suspension while the car is moving.
Jump to top akaveli3 is offline   Reply With Quote
Old Tue, Nov-03-2009, 11:36:34 PM   #10
timexp99
Reputation: 0 timexp99 has disabled reputation
love to know the cause, my 02 is doing the same thing...
Jump to top timexp99 is offline   Reply With Quote
creaking, front, suspension
Discussing Creaking front front suspension HELP! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
