E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#21 |
![]() Location: So-Cal
so whats the easiest way to achieve this as you would have to remove the wheels to adjust the coilovers.
Sponsored Links |
#22 | |
40 something
![]() Location: San Diego
![]() Quote:
Now a 2" drop is a different story altogether.... ![]() |
#23 |
40 something
#24 | |
visor up for pleasure
![]() Location: Westchester, NY
![]() Quote:
#25 |
RS-aholic
![]() Location: KY
rake is the key
'13 E92 M3 Coupe - Daily '00 Miata - DE toy '11 E92 M3 Coupe - track build starting '12 Cayenne '09 Ford F350 DRW - tow rig |
#26 |
So you change it until you get it just right, then you must do an alignment correct? And each time you change the height from then on, its a new alignment?
#27 |
heres 13.5 / 13.5 on mine
guess i will lower the back a bit later what about the rebound settings?
2006 ZCP SilverGrey/Imola |
#28 |
Ok, so looking at the 13.5 F & R, I guess I would like 12.5 drop for F & R and hopefully, I would still have a decent street ride if I adjust the spring rates right.
#29 |
![]() Location: Washington, DC
12.5 up front is really iffy for ride quality. You need quite a lot more spring to cover for the huge loss of travel. Think 700lbs, instead of 400-450.
[B]2011 BMW M3 (E90) Alpinweiß/Cloth - Slicktop stripper, TCK D/A Konis, AS SSK 2006 GMC Sierra 2500HD 4WD - Duramax LBZ/Allison 2002 BMW M3 Alpinweiß/Black - Konis, AS SSK, JBL MS-62C, IDQ-12v3, JBL MS-8 1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod 1995 M3 Dakargelb/Black - S50B32/S6S420G, Diffsonline 3.91, H&R/Bilstein, Hotchkis, AS SSK, etc... 1990 325is Brilliantrot/Tan - GC/Bilstein, Sway 1989 325is Alpinweiß/Black - Decontenting... 1989 M3 Alpinweiß/Black - S62B50 in progress... Hers: 1996 Porsche 911 Turbo Black/Black - UMW LTW Flywheel, Bilstein Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, 272 cam, H&R/Bilstein ![]() |
#30 |
Ok, I guess the cool thing is you can experiment until you get it right...
Bookmarks |
Tags |
13 rear and 135, front, height, pics |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
19" CSL Replicas Front - 19" OEM ZCP Rear | E46M3FTW | E46 M3 (2001-2006) | 5 | Mon, Mar-31-2008 08:52:45 PM |
FS: Brembo 15" front 13.6" rear GT brake kit drilled/ $4500 | edmo7 | Parts for Sale/Wanted | 0 | Fri, Sep-07-2007 01:32:09 AM |
Differences between 8.5" or 9"front and 10"rear setting? | Micro | E46 M3 (2001-2006) | 4 | Wed, Oct-05-2005 03:43:14 AM |
Iforged 19" x 8" front and 19" x 10 Rear??? | mmihld | E46 M3 (2001-2006) | 1 | Tue, Sep-20-2005 01:00:15 PM |
Brembo GranTurismo 15" front 13.7" rear fit oem 19"? | Kevin034 | E46 M3 (2001-2006) | 4 | Tue, May-24-2005 10:45:56 PM |
