Old Wed, Aug-06-2008, 01:14:56 PM   #21
sqpablo
Lurker
sqpablo's Avatar
Reputation: 0 sqpablo is on a distinguished road
Originally Posted by Nick325xiT 5spd View Post
You'll also want a 36mm-ish socket to (gently) tap the new hub on with. You need to tap the bearing race, otherwise you'll just knock the bearings out of alignment.
Originally Posted by Tonester View Post
Tapping the new bearing in is critical just as Nick posted.. you don't wanna push out the outer race.. then you'll be SOL.
I'm kinda unfamiliar with these parts, is this where to tap? Part alone was over $200 so I want to do this right... thanks again
Jump to top sqpablo is offline   Reply With Quote
Old Wed, Aug-06-2008, 01:42:14 PM   #22
nrubenstein
That's correct. Careful to make sure you're hitting it on straight.
Jump to top nrubenstein is online now   Reply With Quote
Old Wed, Aug-06-2008, 01:43:45 PM   #23
nrubenstein
Originally Posted by oh2fly View Post
You can't miss them: The most obvious is a grinding noise that will get louder as the bearing gets worse. It will be louder tuning in the direction opposite the side the bad bearing is on.
You may also be able to jiggle the wheel when it's off the ground. These are the two most obvious signs I'm aware of.
Also, if you have excessive road noise from one corner of the car, you've got a bearing that's starting to go. If you *think* you might have a bad wheel bearing and want to check, take off the brake rotor and spin the hub. If it makes any noise, replace the bearing.
Old Tue, Dec-02-2008, 02:25:10 PM   #24
APIindy
APIindy's Avatar
Reputation: 0 APIindy is on a distinguished road
This post is awesome and the guide is a keeper. Thanks, for the pics too.
MODS: 03 M3, 6MT, PSS9, 18" OEM Square setup, El Diablo Exhaust, non-resonator section one, Turner Motorsports Rear Adjustable Camber Arms, Powerflex bushings, Stoptech slotted rotors, Hawk track pads, UUC stainless steel brake lines, AFE Cold Air Intake, Hamann front splitter
Driver that grins ear to ear everytime he drives it
Jump to top APIindy is offline   Reply With Quote
Old Fri, Apr-06-2012, 03:33:50 PM   #25
CMendez
Lowly High School Teacher
CMendez's Avatar
Reputation: 0 CMendez is on a distinguished road
Default Re: DIY for Front Wheel Bearing Replacement?
^FWIW I discovered today that my car has a bearing going out. It's making a soft grinding noise at low speeds (~20mph). Going to replace both hubs while I'm at it.
2008 BMW E90 M3- Jerez Black, 6mt
SOLD- 2005 BMW E46 M3- Interlagos Blue ZCP, 6mt
Jump to top CMendez is offline   Reply With Quote
Old Sun, Apr-08-2012, 01:38:16 AM   #26
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
These make such a huge difference. The car rides and tracks so nice after changing these out . Car cruises at 80mph with one finger on the wheel..... Not that I'm promoting that, just sayin...
Sent from my iPhone using my fingers
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Tue, Apr-16-2013, 04:03:39 PM   #27
kokgo20
kokgo20's Avatar
So we have to replace the whole hub (hub+bearing)? bearing is not sold separably?
Build thread
Jump to top kokgo20 is online now   Reply With Quote
Old Wed, Apr-17-2013, 05:27:14 AM   #28
kokgo20
kokgo20's Avatar
Any comments?
Build thread
Old Wed, Apr-17-2013, 11:03:06 AM   #29
turbomw
turbomw's Avatar
Reputation: 0 turbomw is on a distinguished road
Yes, the hub can only be replaced, $180+ per side
03' SMG - Evolve-R/K&N/Eibach/Koni/Hawk/AP Headers&Muffler/CPI Euro200R/TMS Pulleys/MINI battery
Jump to top turbomw is offline   Reply With Quote
Old Wed, Apr-17-2013, 04:00:41 PM   #30
kokgo20
kokgo20's Avatar
how did your car/ steering wheel feel before changing them?
Build thread
bearing, diy, front, replacement, wheel
Front wheel bearing/hub DIY ? Special tools? m3keeper E46 M3 (2001-2006) 16 Fri, May-10-2013 11:14:04 PM
Advice on rear wheel bearing replacement jskene E46 M3 (2001-2006) 6 Sun, Aug-07-2011 11:53:17 AM
Any wheel bearing DIY? Silver///M Faults, Fixes and DIY 3 Tue, May-20-2008 12:26:58 PM
rear wheel bearing DON'T DIY EMMM TREE E36 M3 (1992-1999) 3 Wed, Aug-30-2006 12:47:13 AM
CPO vs Clutch and wheel bearing replacement so gti E46 M3 (2001-2006) 1 Thu, Aug-03-2006 08:46:31 PM
Discussing DIY for Front Wheel Bearing Replacement? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
