Old Mon, Oct-02-2017, 05:41:36 AM   #1
rovert604
rovert604's Avatar
Default Do KWV2 rear struts rebound...
...when I use my hand to compress them, automatically?
I thought a shock should bounce back in a controlled manner but I've been getting different answers.
Just wanted to know if anything was wrong. I see no sign of leakage or oil anywhere.
--Trevor in 604--
Vancouver, BC, Canada
Old Mon, Oct-02-2017, 06:49:20 AM   #2
Default Re: Do KWV2 rear struts rebound...
Pull on them to test rebound. If they resist well and even, if you can't pull them out easily, then they're ok. Pretty impossible to tell HOW good they are by hand, I mean telling whether they've got 90% life left or 50%. More of a test of whether they're blown out or not.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · SPC alum rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · 12mm/10mm F/R spacers · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Tue, Oct-03-2017, 12:11:53 AM   #3
rovert604
rovert604's Avatar
Well I know when I drove my car I never felt any bouncy, bouncy like a Chevy Caprice going over a speed bump with springs only. My car twerks in a very controllable Cyrus manner. LOL.
I just cleaned up the shocks and by using my own strength, compressing or pulling the shock up is slow and steady. There is no play or any unsmooth movement. I noticed that if I pressed down with all my might in a sharp hit the shock would compress then bounce up just a tad when I let go as it recovered, all the while I can hear fluid/oil inside the tube moving from one side to the other.
--Trevor in 604--
Old Tue, Oct-03-2017, 12:39:05 AM   #4
They could be at that point where they're not completely gone, seem fine in your hands, but can't rebound enough to control the car. A bouncy car is a sign as you know. Is this with them adjusted to slowest rebound (stiff/full)?
_
Old Tue, Oct-03-2017, 12:48:31 AM   #5
bluptgm3
I don't believe KW are gas pressure shocks.
Most single adjustable shocks are only adjustable in rebound.
Old Tue, Oct-03-2017, 01:55:08 AM   #6
rovert604
rovert604's Avatar
I just did another test with them on full stiff. I realize that KWV2 adjust just rebound. Compression is static and on adjusting.
On full stiff it took more strength to extend the shock and even then, the shock extended far slower than when I had it on full soft. Compressing was the same speed no matter what setting. Guess that is working!
--Trevor in 604--
Old Tue, Oct-03-2017, 02:52:42 AM   #7
EricSMG
40 something
Trevor - I just realized after all these years that your screen name it your name backwards.
Son of a....
2004 E46 M3 6MT SG/Black
Old Tue, Oct-03-2017, 03:09:38 AM   #8
twentyseven
@itsmejonnyv
twentyseven's Avatar
Son of a....
V-CSL, BBS CH, Öhlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Tue, Oct-03-2017, 03:20:05 AM   #9
rovert604
rovert604's Avatar
LOL Eric! Back on topic! Or is my shock fine? LOL
--Trevor in 604--
Old Tue, Oct-03-2017, 02:17:39 PM   #10
Zroman610
Zroman610's Avatar
Reputation: 0 Zroman610 is on a distinguished road
I have v1's that I got from a buddy that have quite some mileage on them (I'd guess 20-30k miles but actual is unknown). I remember when installing that the struts compressed rather easily and my car feels VERY soft/saggy in the rear as you explained in a previous reply. I plan to have them rebuilt over winter but the more I read about KW v1 and v2, it seems like other people say the same thing about being a very soft setup. Now I'm on the fence between a rebuild (~$500 from KW) or new coils with linear springs (~$2k+).
Do you know the mileage on yours? I'm wondering if the springs also wear out over time, even though the KW rep claims it is most likely just the struts.
Jump to top Zroman610 is offline   Reply With Quote
Discussing Do KWV2 rear struts rebound... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
