Old Mon, Nov-19-2012, 05:42:51 AM   #41
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
Default Re: LED license plate lighting....
Do these cause any error message? I just ordered the 36mm (2x5050) 2-LED ones.... I hope these are nice....
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Mon, Nov-19-2012, 12:05:27 PM   #42
Skulinex
Reputation: 0 Skulinex is on a distinguished road
Originally Posted by Pendulum View Post
I got the 39mm 3 LED bulbs from DDM. They fit almost perfectly, needed slight bending of the contacts but other than that they are a nice white and aren't too bright. I did notice however that they still draw some power after all the lights are off and shine faintly for a few minutes before they shut off. I'll get some pictures tomorrow.
that happens with any small outside bulb you might replace with LEDs. Not an issue and they simply stay on until with the car's computer. To check this, just look at your dashboard after you lock the car and the LEDs should shut off when the dashboard does too.
Jump to top Skulinex is offline   Reply With Quote
Old Mon, Nov-19-2012, 12:33:22 PM   #43
JokerElite
JokerElite's Avatar
Reputation: 0 JokerElite is on a distinguished road
No error messages here. If I find time when it's dark out I'll try to take some pictures. I was looking for lights that weren't overwhelmingly bright, but were white in color and I think these do the job well. There's still a cutoff line on the ground but it's not as bad as others I've seen.
1995 BMW M3 | 2004 BMW M3 | 2009 BMW 328xi
Jump to top JokerElite is offline   Reply With Quote
Old Mon, Nov-19-2012, 12:59:20 PM   #44
skelzy
Great White
skelzy's Avatar
Good to know... Can't wait until they get here. I'll post some pics as well when they come for others to judge
Old Mon, Nov-19-2012, 01:19:33 PM   #45
MikeS123
Reputation: 0 MikeS123 is on a distinguished road
Originally Posted by I M Legend View Post
These are about the same brightness as stock and are white in color
Amazon.com: Sylvania 6418 LEDriving Premium White Interior Light, Pack of 1: Automotive
I just bought this one. It is a close match to the LED I have in my back up camera. They are usually in stock at your local Advance Auto Parts. Not as bright as some of the vendors on here, but I don't like them that bright, no need for aircraft to be able to read your license plate at night.
Jump to top MikeS123 is offline   Reply With Quote
Old Mon, Nov-19-2012, 08:54:51 PM   #46
I bought these too as I was looking for something that emitted white light without rivaling airplane landing lights - and for that they're perfect.
Only thing is I noticed that they seem to stay on at a reduced brightness after shutting down the car. They do finally turn off after about 15 minutes. Does your car do the same?
Old Mon, Nov-19-2012, 09:09:52 PM   #47
Pendulum
Pendulum's Avatar
Reputation: 0 Pendulum is on a distinguished road
Seems as though most LEDs do this unless you are running resistors.
Jump to top Pendulum is offline   Reply With Quote
Old Tue, Nov-20-2012, 01:53:15 PM   #48
JokerElite
JokerElite's Avatar
Haven't gone out to take pictures of them on the car but here are pictures of the 36mm ones from DDM Tuning. They're labeled so you can see which is which. Also the pictures show front and back. I like the ones with 2 LEDs because they're not as bright and actually enclosed in a capsule while the one with 4 LEDs are exposed.
Old Tue, Nov-20-2012, 02:48:07 PM   #49
MikeS123
I know the LED in my back up camera stays on for a while. I hadn't noticed the one I bought from Advance staying on, but it probably does but the other one stays pretty bright so I just might not have noticed it.
Old Wed, Nov-21-2012, 12:26:50 AM   #50
skelzy
Great White
skelzy's Avatar
These are the exact ones I ordered ..... Do these have resistors built in? I'm asking because I heard you only get a warning from LED's with out resistors and these supposedly give off no warning lamps....
led, license, lighting, plate
Discussing LED license plate lighting.... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
