Old Tue, Jun-23-2015, 08:34:58 PM   #51
dhigham
Reputation: 0 dhigham is on a distinguished road
Default Re: Comprehensive CSL Intake Thread
Hey guys, I am troubleshooting a problem with my CSL airbox conversion. I've installed the TTFS MAP rail / MSS54HP ecu / GSR airbox. Everything runs fine, but the car has ZERO power (by zero, I mean Camrys are pulling off the line ahead of me without trying... and my pedal is to the floor). It is very sad, yes. My car ran perfect before the conversion with a standard TTFS tune.
All of my wiring seems to be okay (tested with a volt meter and datalog shows all sensors to be working). Car runs perfectly smooth, starts fine cold/warm, idles fine, accelerates fine (but does so VERY slowly). I originally tried running the car without moving the fuel pump relay pin from X60002 Pin 11 -> X60004 Pin 10, and today switched the pin over to the empty slot in X60004 with no noticeable change (runs almost the same, maybe a little more power). Here are some more details which may help:
-Stock US cams (not-CSL)
-Jun '01 build vert
-6MT
-No flap
-Green fuel pump relay (came this way from factory... pin locations were verified today)
-3 error codes: 6, 124, 130
I am waiting for a reply from TTFS but maybe someone on here can help.
*PS thanks to the OPs for all the info it made the wiring conversion very straightforward.
Jump to top dhigham is offline   Reply With Quote
Old Thu, Jun-25-2015, 09:48:44 PM   #52
dhigham
-Jun '01 build vert
-6MT
-No flap
TTFS sent a revision to the tune and that fixed the problem. Not sure what the tune parameters were or if the car was in limp mode with no indication.
As for the conversion the car feels awesome with the new MAP rail setup and the growl/ power is awesome at WOT. Very pleased with the conversion so far!
Old Thu, Oct-01-2015, 10:25:20 PM   #53
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
The wiring DIYs show replacing the wire in Pin 17 of x60003 with the ground from the MAP sensor. What does that wire originally ground? If anyone has a full MSS54HP wiring diagram, I guess that would be helpful and answer my question. I couldn't find one by searching.
I originally wired the ground to Pin 16 which was suggested in another thread. I have had a sub 3000rpm hesitation which I have been chasing and a cold start, rough running problem. If I unplug the MAP sensor, the car seems to behave better. I was chasing VANOS and TPS issues, but the VANOS checks out now, as does TPS. So, on to the MAP and associated wiring/tuning.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Thu, Nov-19-2015, 01:38:52 PM   #54
Dave B
M3 collector
Dave B's Avatar
Italy
Originally Posted by m3dragon View Post
Alternator signal (March 2004+ Cars)
  • Requirements:
    • 12527510674 x 2 (Cluster and DME pins)
    • 22 AWG wire
  • Pinout: Black Connector Cluster Pin 2 -> X60004 Pin 1
  • Coding: Set “GENERATOR_UEBER_CAN” to nicht_aktiv
What is "black connector cluster" as listed here? Is it the 8-pin guy on the driver side wall of the box next to the 4-way split of the hot wire? (It comes from the engine harness.)
There's an empty pin on the 3-pin alternator plug itself, but it's not #2, plus I assume if that was where this was going it'd just say that connector by name...
Old Thu, Nov-19-2015, 02:09:09 PM   #55
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
Use the pin out instructions.
All you are doing is punching pins in or T tapping them.
Ignore all the garbel speak.
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Thu, Nov-19-2015, 08:20:23 PM   #56
Dave B
M3 collector
Dave B's Avatar
Italy
That's what I'm confused by. Pins out of pin 2 of something I'm not understanding (as opposed to "X60004" or "MAF harness, which I can identify). What is "black connector cluster?"
Old Thu, Nov-19-2015, 09:48:51 PM   #57
Should say "black connector of cluster" - as in literally the black connector that plugs into the instrument cluster (there's a black one and a white one)
Old Fri, Nov-20-2015, 02:07:19 PM   #58
Dave B
M3 collector
Dave B's Avatar
Italy
IAT Sensor
  • IAT pin 2 to MAF harness pin 3 or DME X60003 pin 14 (Ground)
Flap position sensor
  • FPS pin 3 to MAF harness pin 4 or DME X60003 pin 14 (Power)
Found another... same pin being used as power and ground on different things? Typo? Is there a reason we aren't just following the CSL pins and use X60003 pin 25 for IAT's ground?
(I'd just use the MAF but I don't actually have that harness anymore. Actually I'm just going to plug things in wherever Terra tells me to anyway.)
Old Fri, Nov-20-2015, 07:43:41 PM   #59
Yeah that seems like a typo. I *think* the ground is supposed to be pin 15, but I have to double check that.
You can just follow the CSL pins, but those pins are used for ground for a lot of things, so it adds some work compared to just reusing an existing ground or running a wire to one of the unused grounds
Old Fri, Nov-20-2015, 10:07:23 PM   #60
Dave B
M3 collector
Dave B's Avatar
Italy
25 - (OE location is 22 and 25 for IAT) had an existing ground in it so I ended up hacking into that one, which ended up being far messier than I had hoped since I had a nice perfect length pinned end ready to go in. I was too lazy to run back inside and up to the computer to check the diagrams to see if any other pins (ie 15 that you mention) might also be grounds.
Speaking of pins in use, two of the three flap motor pins were occupied too. I left it alone and will re-visit that when I actually get a snorkel.
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
