Old Sun, Oct-03-2010, 12:25:41 AM   #1
Lee22
Lee22's Avatar
Reputation: 0 Lee22 is on a distinguished road
Default where is there a DIY to change Fuel Injectors?
did some searching but couldn't find anything on how to change your Fuel injectors. a step by step and pics would be helpful.
H&R Rss Club Sport Coilovers For Sale
Jump to top Lee22 is offline   Reply With Quote
Old Sun, Oct-03-2010, 08:53:48 PM   #2
Lee22
Lee22's Avatar
No one, has info on this?
Old Sun, Oct-03-2010, 11:11:26 PM   #3
///M3AN ONE
Live life to the fullest...
///M3AN ONE's Avatar
Reputation: 0 ///M3AN ONE is on a distinguished road
AA had instructions on their old website but just recently changed it. From memory I:
1. Gently take off the fuel rail from the injectors. Be careful not to pull out too hard.
2. Pull out retaining clips from each injector.
3. Gently wiggle out each injector.
4. Reverse steps with new injectors.
Be extra careful when installing the new ones. These can get damaged very easily from pushing on the fuel rail.
Jump to top ///M3AN ONE is offline   Reply With Quote
Old Mon, Oct-04-2010, 03:44:43 AM   #4
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
Oh man, the fuel injectors are a pain in the butt to do. M3anOne has outlined it correctly. Take your time prying the fuel rail off, and then removing the clips from the injectors.
I had written a bit out this procedure when I was doing mine:
http://m3forum.net/m3forum/showpost....6&postcount=28
Jump to top toy4to is online now   Reply With Quote
Old Mon, Oct-04-2010, 03:46:58 AM   #5
Rendezvous
Rendezvous's Avatar
Reputation: 0 Rendezvous is on a distinguished road
Germany
Did any of your injectors fail?
Jump to top Rendezvous is offline   Reply With Quote
Old Mon, Oct-04-2010, 03:53:55 AM   #6
toy4to
Lemonade Tycoon
If this question was directed to me, then no, my injectors didn't fail. I replaced them because I was in the process of installing my AA supercharger kit. The kit is supplied with bigger injectors.
Old Mon, Oct-04-2010, 09:35:59 PM   #7
Lee22
Lee22's Avatar
my car started to misfire and i had to limp it back home. after checking the ignition coils and determining that they were not the problem i ran an OBD2 scanner and got this code.
the details of the problem are here with more pics http://www.m3forum.net/m3forum/showthread.php?t=336301
Old Mon, Oct-04-2010, 10:38:55 PM   #8
azndrunk74
Reputation: 0 azndrunk74 is on a distinguished road
Taiwan
"injector circuit open". i had that error before. my wiring harness was loose where it connected to the injector. i used a screwdriver and widened the prongs a little bit so they fit snug into the injector, problem gone.
LSB|Cinnamon
Jump to top azndrunk74 is offline   Reply With Quote
Old Tue, Oct-05-2010, 02:09:14 AM   #9
Lee22
Lee22's Avatar
Hrmm, I'm gonna check that when I get home
before trying to replace an injector. Thanks for that info bro
Old Tue, Oct-05-2010, 04:07:36 AM   #10
azndrunk74
Taiwan
no problem. i had actually replaced the injector thinking it was bad but the problem was still there. after fixing the prongs in the harness, the issue went away. good luck!
LSB|Cinnamon
change, diy, fuel, injectors
Discussing where is there a DIY to change Fuel Injectors? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
