Old Mon, Jan-26-2009, 01:31:55 AM   #1
silverstare46
Reputation: 0 silverstare46 is on a distinguished road
Smile anyone know how to change A/C blower motor e46?
Does anyone has DIY step by step pic to replace a/c blower motor E46?
Please Help me. My A/c fun has whistling noise so at least I want to clean up the motor to fix the problem.
Thanks
Jump to top silverstare46 is offline   Reply With Quote
Old Mon, Jan-26-2009, 01:33:33 AM   #2
jjojo2004
GR68JOJO
jjojo2004's Avatar
Reputation: 0 jjojo2004 is on a distinguished road
I'd like to see a DIY on this myself!
Jump to top jjojo2004 is offline   Reply With Quote
Old Mon, Jan-26-2009, 02:02:26 AM   #3
tony(topaz,SMG)
Reputation: 0 tony(topaz,SMG) will become famous soon enough
Hopefully the dash doesn't have to come out like on other BMWs I've had.
Jump to top tony(topaz,SMG) is offline   Reply With Quote
Old Sun, Feb-07-2010, 08:15:52 PM   #4
G-Dot
Mmmmm 3
Reputation: 0 G-Dot is on a distinguished road
My fan died last night and is now working this morning. I also would like to understand how to access the blower so I can check connections etc. Doing some reading it looks as thought the blower resistor (FSU) may be the culprit but want to check connections first before replacing something that may not need to be replaced.
Jump to top G-Dot is offline   Reply With Quote
Old Sun, Feb-07-2010, 09:03:10 PM   #5
B1G
DIFFERENT !
B1G's Avatar
Reputation: 0 B1G is a jewel in the rough
Check this out... Starting with post #11
http://forum.e46fanatics.com/showthread.php?t=418987
Note: I followed these instructions, but I gave up trying to remove the blower. All bolts were off and the motor was in my hands. I just never managed to take out. The darn blower is too big to fit between the engine body. Maybe it has something to do with the s54 engine being higher in the engine bay ???
= [19"] NEEZ Eurocross Super = [18"] RAC RG63 = Yokohama Advan Sport = TCK SA 450/500 = PowerFlex RTAB's = LED Angle eyes = Custom molded CSL style splitters = Fog delete with custom fiberglass filler duct = Re-wired fog light switch (now turns on inners) = Nokya yellow halogens (inners) = Painted exterior part of kidney grills = Painted (no CF exposed) VCSL diffuser = Custom airbrushed interior trim = 6 series SMG shift knob = GSP Brake pedal = Kenwood Double Din = Eclipse AMP = Sub-frame reinforcement (Thanks to the great guys at BimmerShop) = Streamline drop in filter = Aluminum shift paddles = Lightwerkz 55w Xenon uipgrade
PICS
(1) Views and opinions expressed in my posts, are my views and opinions and in no way is it implied that they are the views of the mass.
Jump to top B1G is offline   Reply With Quote
Old Sun, Feb-07-2010, 09:08:42 PM   #6
antknee
Reputation: 0 antknee is on a distinguished road
on my old E30 it was easy as hell to access. There was an access panel on the firewall that allowed you to remove it. hope for your sake its just as easy on the E46
www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
Past:
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
Jump to top antknee is offline   Reply With Quote
Old Fri, Mar-11-2011, 03:42:31 AM   #7
Mystical
Mystical's Avatar
Reputation: 0 Mystical is on a distinguished road
Default Re: anyone know how to change A/C blower motor e46?
B1G, did you remove the engine cover to get more clearance? That's what I had to do on my E46 323i, then it came out easy. Was going to help someone with his M3, but after reading your post, I'd like to understand your issue a bit better so I don't get stuck in the same situation.
Jump to top Mystical is offline   Reply With Quote
Old Tue, Dec-31-2013, 07:15:03 AM   #8
stolidog
stolidog's Avatar
Reputation: 0 stolidog is on a distinguished road
Thread revival.
I'm assuming someone has had luck replacing their blower motor, but all I see is that they couldn't get the fans out or in without breaking the fan blades. Who has done it and what tips/insights might you be able to provide? The Bentley manual makes it seem like a pretty easy job on a non-M e46, but makes no mention of differences with the M.
Second question is, if someone has done this, have they been successful using the X3 P/N as mentioned in the link above? $500 for the E46 part vs $100 for the X3 part that the non-M e46 peeps are using… thats a hefty difference.
2004 E46 M3 Tiag - 6 Speed, Blk Interior, OEM 19's
Current Mods:330d Shifter, Orion V2 4300k, TIAG reflectors
2014 Ducati 899 Panigale - Red
Current Mods:LSL Footpegs, Techspec Snake Skin, Opticoat Pro, DP Lower Radiator Guard
2016 X4 3.5i M-Sport - Dark Graphite Metallic
Jump to top stolidog is offline   Reply With Quote
Old Tue, Dec-31-2013, 03:14:40 PM   #9
nowanker
"He's no wanker!"
Don't know if the X3 fan fits, if it works, let us know!
My copy of TIS says remove the intake manifold for access, otherwise the same as base e46.
Never done an M3, but have done a regular e46. It wasn't too tough, but pay attention to the direction of rotation. The blower fits either way, and when it's backwards it doesn't flow any air. Makes all the right noises, you think you're done... it's more fun the second time.
Old Tue, Dec-31-2013, 06:47:27 PM   #10
stolidog
stolidog's Avatar
Thanks, that's good info... at least from a preparedness standpoint. If the non-M e46's can run the X3 blower, I have a hard time imagining that the M model cant as well. RealOEM shows the same P/N for both M and non-M.
a or c, blower, change, e46, motor
blower motor help MXV1496 E36 M3 (1992-1999) 1 Wed, Jun-04-2008 04:09:49 PM
a/c blower motor madkimchi E36 M3 (1992-1999) 9 Tue, Sep-18-2007 10:02:38 PM
Blower Motor LudjakR1 E36 M3 (1992-1999) 12 Tue, Jun-26-2007 07:55:08 PM
Blower Motor Resistor rokayama General BMW Discussion 1 Mon, Jul-31-2006 07:03:36 AM
Blower motor DIY emfollin E36 M3 (1992-1999) 1 Tue, Feb-14-2006 05:44:09 AM
Discussing anyone know how to change A/C blower motor e46? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
