Old Thu, Jun-29-2017, 01:04:21 AM   #1
Acalyst
Reputation: 0 Acalyst is on a distinguished road
Default How to Look for a Broken/Clogged Catalytic Convereter
Hey guys, my e46 M3 started losing its exhaust noise a few months back and it has never been the same. After driving the car for 5 mins or so and everything warms up, the car just sounds muffled and I was led to believe it might be a clogged cat. The car is currently running catless headers and MangaFlow Race cats in section 1. I took them out and I am just curious what to look for. Also, what else could be causing the problem other than the cats?
Jump to top Acalyst is offline   Reply With Quote
Old Thu, Jun-29-2017, 03:44:41 AM   #2
mleveroni
Reputation: 0 mleveroni is on a distinguished road
Default Re: How to Look for a Broken/Clogged Catalytic Convereter
Not sure if its really possible to clog a cat. If anything it would start ejecting itself out the exhaust and make the car louder. But if you want to look it should just look like a honey comb. The car should quiet down after it warms up, it is to get the cats up to operating temperature quicker. Are you sure you haven't just gotten used to the noise? If so your problem is easily solved by a louder exhaust.
2002 M3 Carbon Black 6MT
ARP Headstuds|ARP Rod Bolts|Beisan Vanos|Topspeed Exhaust|AR20's|Ebay Headers|Turner Subframe Plates|ZCP Rims|Custom Rear Strut Bar|AKG Bushings|ST XTA Coilovers|Clutchmasters FX300 Clutch/Aluminum Flywheel|RK Tune
Jump to top mleveroni is offline   Reply With Quote
Old Fri, Jun-30-2017, 02:14:31 PM   #3
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
When I installed my headers and removed my OE header/cat combo, one of them was rattling and when I shook it, pieces of the cat fell out. Weird thing is I had just passed an emissions test a month earlier with the sniffer at the tail pipe so it must have been still working.
I have heard of aftermarket cats getting 'clogged' but from my understanding it's due to either excessive fueling creating so much black soot it clogs the honeycomb or excessive heat from lean conditions melting the metals that are in the honeycomb. In both cases it's bad tuning + time.
Jump to top Ramp1 is offline   Reply With Quote
cats, diy, exhaust, muffled
Discussing How to Look for a Broken/Clogged Catalytic Convereter in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
