Old Wed, Feb-12-2014, 03:41:50 PM   #11
azn101
azn101's Avatar
Reputation: 0 azn101 is on a distinguished road
Default Re: DIY: exhaust camshaft position sensor.
i just did the exhaust sensor and my car still have code "a" camshaft position slow response bank 2 it that mean my intake sensor is bad
Jump to top azn101 is offline   Reply With Quote
Old Mon, Mar-31-2014, 09:43:05 PM   #12
Taiyo
Reputation: 0 Taiyo is on a distinguished road
Thanks for the info!
Jump to top Taiyo is offline   Reply With Quote
Old Thu, Apr-17-2014, 12:05:14 AM   #13
M3_Power_Hustle
Reputation: 0 M3_Power_Hustle is on a distinguished road
My car has been throwing codes P0013 Exhaust Camshaft position actuator circuit and
P0014 Exhaust Camshaft position timing over advanced (bank 1). I'm also getting p0420 and p0430 Cat. system below threshold. The car has been terrible in colder weather and feels like it's only running on 3 cylinders, very unresponsive at very high or very low rpms.
Yesterday it decided not to start at all. I found that my clutch fan had been running with only a few blades, no idea how, but could an out of balance clutch fan running for (at least 3 months) be the culprit of all this mess? 2001 M3 112,000. Any suggestions would be great. Cant even get it started, but starter does turn over.
Jump to top M3_Power_Hustle is offline   Reply With Quote
Old Fri, Jan-16-2015, 11:14:15 PM   #14
pip86
Reputation: 0 pip86 is on a distinguished road
Anyone have any insight into why the sensor was enlarged? I have been leading oil from the sensor location so I replaced the o-ring but it has continued to leak. CPV, VCG, and tensioner gasket, banjo bolt gaskets all new and not leaking. I can see and feel the oil coming or from around the sensor. So either that is the worst OEM o-ring or I need to replace the sensor as well because something isn't right.
Jump to top pip86 is offline   Reply With Quote
Old Sat, Jan-17-2015, 04:47:32 PM   #15
pip86
New sensor is 18.32mm according to a tech at the dealer I called.
Old Sun, Jan-18-2015, 10:04:44 PM   #16
AP22
AMG.
Reputation: 0 AP22 has disabled reputation
I have the same exact leaking issue. I replaced the o-ring a week ago but am still experiencing a leak.
Take a look at my thread and let me know if this is what you're experiencing.
http://www.m3forum.net/m3forum/showthread.php?t=495458
Have you replaced yours yet? And if so, has the leaking subsided?
AMG ftw.
Jump to top AP22 is offline   Reply With Quote
Old Mon, Jan-19-2015, 05:06:13 PM   #17
pip86
Replaced the o-ring with same leaking issue. Not sure why the o-ring didn't fix it. Ended up buying a new upgraded sensor which is thicker (18.32mm vs 17.88mm). Should arrive in a week and then I'll update. For now I'll have to drive the DD.
Old Mon, Feb-02-2015, 03:00:21 AM   #18
AP22
AMG.
Any update? ^
AMG ftw.
Old Tue, Mar-01-2016, 01:40:39 AM   #19
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
did this today. i agree taking off the plastic valve beauty cover gives more roon to work. it's really at an odd angle but if you use a mechanics mirror to view before it makes it easier to figure out. i was having a akward time getting the 5mm allen bit to find the bolt. but found starting it with an allen key to break it loose and then move to the bit and ratchet easier.
2003 TiAg - OE CSL WHEELS - OE CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER
SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GRUPPE M CF INTAKE - CF RACE LIP - 4.10 M DIFF - CSL RACK - GROUP N MOTORMOUNTS
-SANS SUNROOF-
Jump to top OldFanatic is offline   Reply With Quote
Old Thu, Mar-03-2016, 06:05:31 AM   #20
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
the o-ring area is the same but the first step down to the cylinder of the sensor is wider on the new version. this might make the possibility of it leaking less
the base where is mounts to the head is now square, where the old version was round.
here are the two for comparison.
SUPERSPRINT EXHAUST
-SANS SUNROOF-
camshaft, diy, exhaust, position, sensor
Discussing DIY: exhaust camshaft position sensor. in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
