Old Sat, Apr-24-2010, 02:24:01 AM   #21
tony(topaz,SMG)
Reputation: 0 tony(topaz,SMG) will become famous soon enough
If it's not too far off you can use heavy duty zipties to compress the rubber mounts in a manner that raises the tips slightly. I'm very picky about my exhaust tips being perfectly symmetrical. That's what I did and it's been fine for a couple of years so far.
Jump to top tony(topaz,SMG) is offline   Reply With Quote
Old Fri, Aug-26-2016, 09:35:52 PM   #22
JokerElite
JokerElite's Avatar
Reputation: 0 JokerElite is on a distinguished road
Default Re: is my exhaust too low, and how to adjust
Originally Posted by mredwin25 View Post
try adjusting the two flanges where the muffler connects to the sec 2, loosen the bottom two nuts on both flanges a little bit and start by adjusting the top ones first, tighten the top two nuts a bit more than the bottom ones, it helps and by doing that it makes the exhaust tilt up a little bit therefore closing the gap in between the tips and the diffuser.
Bump, but for future reference this only offsets the gaskets inside and around the pipes. And tightening with an offset gasket results in bent bolts or flanges.
My hangers are in good shape and everything is torqued to the specified amount. How much spacing should there be between the tips and diffuser? Anyone use longer bolts with washers for lateral adjustment of the muffler?
1995 BMW M3 | 2004 BMW M3 | 2005 BMW X5 4.4i | 2009 BMW 328xi
Jump to top JokerElite is offline   Reply With Quote
Old Fri, Aug-26-2016, 11:27:55 PM   #23
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
I hate to hijack this thread but I'm gonna bump with a pic of my suuuuuuper low hanging exhaust. The car's on jacks right now so I'm gonna give adjusting it another shot. The right solo exhaust hanger was torn so until I get new ones, It's been swapped to the front-most hanger on the left side. The other two hangers look completely fine to me.
Any suggestions are appreciated.
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
adjust, exhaust, low
Discussing is my exhaust too low, and how to adjust in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
