Old Sun, Dec-17-2017, 03:42:53 AM   #1
djjvr
OEM+
djjvr's Avatar
Denmark
Default Intermittent Red Battery Light
So I have been getting an intermittent red battery light which I understand is an indication of a alternator issue as the battery is not being charged. Roughly two years ago I had the red light come on, the the car died, and then I replaced the alternator with a remanufactured Bosch unit. I have heard that these re-man'd units are hit and miss, leading me back to thinking that's my culprit. However, usually when the light comes on I can rev up to about 4k rpm and the light goes away entirely. It isn't till later that it comes back. Just wanting to make sure that is still something that is a typical indicator of an alternator, or if there is something else I should be looking at. Thank you for your input.
"Sucking at something is the first step to being sorta good at something!"
Build Journal Instagram
Old Sun, Dec-17-2017, 04:44:42 AM   #2
Default Re: Intermittent Red Battery Light
It's your alt. Get a new valeo one.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs · ZHP 13.7:1 P/S Rack
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Sun, Dec-17-2017, 05:13:14 PM   #3
djjvr
OEM+
djjvr's Avatar
Denmark
That's what I was thinking. Thank you!
Old Mon, Dec-18-2017, 01:00:03 AM   #4
E46Hoonigan
E46Hoonigan's Avatar
Reputation: 0 E46Hoonigan is on a distinguished road
I had this exact thing happen to me, until my alternator finally decided to die in the middle of a left turn lane....
Definitely go with a new valeo one, the Bosh re-manufactured ones don't last half as long as the valeo alternators.
Jump to top E46Hoonigan is offline   Reply With Quote
Discussing Intermittent Red Battery Light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
