Old Sat, Dec-16-2017, 02:44:54 PM   #1
Wake74
Reputation: 0 Wake74 is on a distinguished road
Default Oil Leak - Front Right Engine
After deferring maintenance on the E46 M3 the last couple of years, due to spending too much time and money on the E36 track rat, I'm finally playing catchup. While I was under the car this weekend (yeah MaxJax) replacing both sets of tie-rods (frozen), I noticed a fair bit of oil.
I can see oil drips:
- On bottom of AC compressor
- On front right of oil pan
- Small black cylinder directly behind AC compressor
- I can see streaks on the front of #1 exhaust header pipe. This would explain a touch of oil smell
I'm gathering parts to do the Besian VANOS work over the holidays, and will replace the VANOS gasket place at that time. However, I don't feel a lot of oil leaking front them area.
I can't think of anything else on the left side that is a likely oil leak spot.
Thoughts?
Thanks!
Jump to top Wake74 is offline   Reply With Quote
Old Sat, Dec-16-2017, 02:48:26 PM   #2
GO4BROKE
Reputation: 0 GO4BROKE is on a distinguished road
Default Re: Oil Leak - Front Right Engine
Probably the CPV. Order a Viton gasket.
Sent from my SM-G930V using Tapatalk
Jump to top GO4BROKE is offline   Reply With Quote
Old Sat, Dec-16-2017, 02:57:54 PM   #3
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Upper timing chain tensioner crush washer. Itís a 32mm if Iím not mistaken
AKG||Euro Headers||Tilton Twin Disk Clutch||RTD||Mishimoto||Customized Bimmerworld Race Exhaust||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||Enkei NT03||Nitto NT01||TTFS Tune||2800 lbs
Trackspec Autosports
MMI Vehicle Systems
Ravenol
IG: MD__M3
Jump to top mdavidm3 is offline   Reply With Quote
Old Sat, Dec-16-2017, 02:58:10 PM   #4
Chain tensioner is right above ac pump and, from some of our findings, isn't very tight. I use a dental mirror and flash light to see it. CPV is a very likely culprit it's further back though.
/// 2004 SilberGrau M3 ∑ Coupe ∑ 6MT ∑ slicktop ∑ manual seats ∑ no nav______________________JOURNAL
-Evolve-R Alpha N ∑ Evolve CSL CF Airbox ∑ Eventuri Scoop ∑ AP Headers ∑ Euro cat sect 1 ∑ Dinan sect 3 ∑ BMW Motorsport 4.10 ∑ Besian ∑ D/A pullies/fan delete ∑ WPC rod bearings
-TMS Camber & Subf plates ∑ RE Street Trans Mounts ∑ AKG poly SUB/DIFF ∑ SDW RTAB ∑ ZHP knob + UUC DSSR ∑ GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk ∑ APEX 75mm Studs ∑ Sportline 8S 18"x8.5/9.5" ∑ MPSS 245/275 ∑ ss brake/clutch lines
-Pioneer DEH-80PRS ∑ Eclipse PA5422 ∑ CDT HD-6 + WS-100i ∑ CDT EX-530 ∑ 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 ∑ PPI 1600.4 ∑ CDT HD-6 + HD-100 ∑ CDT EX-530 ∑ Clarion 10"
Old Sat, Dec-16-2017, 05:06:24 PM   #5
Wake74
I don't think it can be the CPV, as that would be leaking much further back. I've got an updated CPV o-ring so that's on the to-do list either way. Timing chain tensioner would be in the right spot, replacing the plastic chain guide is in the Besian instructions for the anti-rattle procedure. Hopefully, that will fix it.
Thanks for the suggestions!
Old Sat, Dec-16-2017, 05:08:30 PM   #6
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Reputation: 0 CLAWHAMM3R is on a distinguished road
+1 chain tensioner
2004 ///M3
Jump to top CLAWHAMM3R is offline   Reply With Quote
Old Sat, Dec-16-2017, 05:13:55 PM   #7
mrgizmo04
mrgizmo04's Avatar
CPV is waaay further back and results in oil accumulation at the back passenger side of the engine right around the tranny bellhousing, so unlikely it's the CPV from your description.
Around where you specify, the black cylinder is the vanos pressure accumulator. Sometimes the high pressure line that connects to the top of it leaks (the other end of it connects to the top of the vanos unit). Sometimes that line cracks and requires replacement along with crush washers for the banjo that is holding it.
Also, as mentioned in the thread, the timing chain tensioner is right above the ac compressor, that can leak by the cyl #1 header.
Could also be your vanos seals in your vanos sealing plate or the vanos gasket that seals the vanos unit to the head. Since the engine sits at an angle, everything drips down to, and accumulates on, the passenger side.
Check those, as those are the most likely culprits. If not there are a few other things to check like timing cover gaskets, front main seal, valve cover gasket, etc.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, full SS (SS stepped V1, catted S1, resonated S2, SS sport), Sachs clutch/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Sat, Dec-16-2017, 06:02:41 PM   #8
Wake74
Excellent post. Thanks!
Old Sat, Dec-16-2017, 06:30:54 PM   #9
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Take it to Forum Member "Kaiv," and he'll fix it right up! That's what I've done.
Jump to top Speed Monkey is offline   Reply With Quote
Old Tue, Dec-19-2017, 02:25:56 AM   #10
mkiv94tt
Clean & Simple
Reputation: 0 mkiv94tt is on a distinguished road
I have the same leak and have been chasing it with little luck.
Jump to top mkiv94tt is offline   Reply With Quote
Discussing Oil Leak - Front Right Engine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
