Old Fri, Dec-15-2017, 09:55:36 PM   #1
straycatgeo
straycatgeo's Avatar
Reputation: 0 straycatgeo is on a distinguished road
Default Tach Warm Up Lights Illuminate at High RPM
Any thoughts as to what might be causing this? Car seems to run fine, but when I get into it, at about 6500-7000 all the warm up lights illuminate until I throw a shift.
Anybody else encounter this? Thoughts as to what might be causing it before I take it into the shop?
Thanks in advance
Geo
Jump to top straycatgeo is offline   Reply With Quote
Old Fri, Dec-15-2017, 09:58:15 PM   #2
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
Default Re: Tach Warm Up Lights Illuminate at High RPM
SMG transmission? I'm almost certain those came with shift lights, which use the same lights as the warm up lights.
Jump to top Zzyzx85 is online now   Reply With Quote
Old Fri, Dec-15-2017, 09:59:33 PM   #3
icecream
Registered Apples
icecream's Avatar
Thanks in advance
Geo
It means the rod bearings are going out.
They are shift lights doood.
Old Fri, Dec-15-2017, 10:00:34 PM   #4
SQ13
Shift lights
Old Fri, Dec-15-2017, 10:14:57 PM   #5
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
Haha shift lights dude. If its a manual and it does it someone coded them to.
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Old Fri, Dec-15-2017, 10:22:22 PM   #6
M3_Pilot
Shift lights dude.
2004 Jet Black/Cinnamon 6MT
Old Fri, Dec-15-2017, 10:36:16 PM   #7
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Im saying shift lights as well BUT they come on at 7500.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Jump to top Sandeep1212 is offline   Reply With Quote
Old Fri, Dec-15-2017, 10:38:32 PM   #8
lmtfi
lmtfi's Avatar
Which valve stem caps are you running?
Old Fri, Dec-15-2017, 11:46:17 PM   #9
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
This! Stop driving your car immediately. Those lights mean there is a critical warning about the internal parts of your engine when in the high revs....
What is happening is, you are getting warnings that are based on the inverse reactive current, for use in unilateral phase detractors. It's what happens when the car is no longer capable of automatically synchronizing cardinal grammeters. The only way to fix this is to replace the faulty part with BMW's replacement encabulator, which works by producing power by the modial interaction of magneto-reluctance and capacitive diractance instead of power being generated by the relative motion of conductors and fluxes, which the original part had (that used an attbase plate of prefabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in a direct line with the panametric fan). This is why you are getting the warning lights.
The replacement part consists of six hydrocoptic marzelvanes, so fitted to the ambifacient lunar waneshaft that sidefumbling was effectively prevented. The main winding was of the normal lotus o-deltoid type placed in panendermic semiboloid slots of the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdlespring on the ‘up’ end of the grammeters. Moreover, whenever fluorescence score motion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm to reduce sinusoidal depleneration. We are talking full motor tear-down and rebuild here. I hope your car is under warranty and not your daily driver. Best of luck.
No. I'm just kidding. They are shift lights. Shift right when they all turn red.
Would love to hear the conversation that takes place had you brought your car to the shop.
IG: DrM3anM3
Mods: Maintenance, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS 'lockdown', Supersprint V1 Stepped headers w/ Oversized Section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, Angel-eyes, CSL SMG Engine DME tune, CSL '255' SMG DME tune, CSL Dynamic Redline Warmup Light parameters.
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Please PM me - In search of:
-- Wanting to Trade basically brand new Eagle Eye Smoked Reverse Trunk Lights for a pair that are Non-smoked
Old Sat, Dec-16-2017, 12:57:59 AM   #10
Joshe46
Joshe46's Avatar
The replacement part consists of six hydrocoptic marzelvanes, so fitted to the ambifacient lunar waneshaft that sidefumbling was effectively prevented. The main winding was of the normal lotus o-deltoid type placed in panendermic semiboloid slots of the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdlespring on the Ďupí end of the grammeters. Moreover, whenever fluorescence score motion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm to reduce sinusoidal depleneration. We are talking full motor tear-down and rebuild here. I hope your car is under warranty and not your daily driver. Best of luck.
This is the funniest post Iíve ever seen!
Discussing Tach Warm Up Lights Illuminate at High RPM in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
